Problem with CRX210E1
Postby assman on Tue Apr 22, 2003 7:06 pm
Hi Guys
I have just bought a Sony CRX210E1 and having problems with it.
When I run Nero, the speeds that it offers me are 2x, and 4x only. I choose to see the specs on the drive through Nero and it tells me that the max speed is only 4x. and not 48x like it should be.
I have since flashed the drive with 2sys2, and have also taken someones advice off this board and tried the lite on firmware and still no luck.
I have tried the latest version of Nero and still have no luck with it.
Is it Nero, or Firmware??
assman
Postby dhc014 on Tue Apr 22, 2003 7:42 pm
It's probably the media...
dhc014
Postby Ian on Tue Apr 22, 2003 8:15 pm
Are you sure that you're not using CD-RW media?
Postby assman on Wed Apr 23, 2003 7:47 am
yeah thanks guys, u are both right
i tried a different disc and sure enough it was working properly
i wasnt aware that the speed changed according to the discs maximum speed
thanx for ur help
assman
Postby dhc014 on Wed Apr 23, 2003 11:10 am
That must have been an old disk!
dhc014
Postby assman on Thu Apr 24, 2003 7:37 am
yeah it was an old disk max write speed of 4x!!!
Cheers
assman
