i have a problem with the popup ads, especailly the ones that popup when i load the Forum Index page even before i log in.
it "kills" the AutoComplete of IE that i ordinarily use for the logon.
usually double clicking the username box "fills" the username and password boxes with the AutoComplete information. but if i've had the popup/slider ad then it doesn't work (double clicking the username box does nothing), and i have to either type the username and password manually or reload the page.
can you fix it so that this doesn't happen, and AutoComplete will work OK after a popup?
