problem w/ Nero 5.5 and Liteon 48x24x48
Postby kab on Sat Feb 01, 2003 1:02 am
Im a beginner at this, so please bear with me.
I am trying to burn what would seem to be a simple data CD off my hard drive, and my burner will not burn at anything higher than 8x. Below is a log file of errors that get generated, hopefully some knowledgable folks here can point me in the right direction.
As far as hardware I am using, I have the Liteon burner, Abit NF-7 mobo, win xp with SP1. The burner is a master on an IDE channel, with a 48x cd/dvd rom drive as the slave (though currently this is swapped, as a friend suggested trying to make the burner the slave).
Anyway, here is the log file:
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero5\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 10:34:54 AM
Nero Version: 5.5.9.13
Recorder: <LITE-ON LTR-48246S> Version: SS0B - HA 0 TA 1 - 5.5.9.13
Adapter driver: <nvidesm> HA 0
Drive buffer : 2048kB
CD-ROM: <JLMS XJ-HD166S> Version: DS0F - HA 1 TA 0 - 5.5.9.13
Adapter driver: <> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800JB-00CRA1 17.0 nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : JLMS XJ-HD166S DS0F nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : LITE-ON LTR-48246S SS0B nvidesm Port 0 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 706MB (723376kB)
Memory in use : 30 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
31.1.2003
CD-ROM (ISO)
11:35:43 PM #1 Text 0 File Isodoc.cpp, Line 6874
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
11:35:43 PM #2 Phase 90 File dlgbrnst.cpp, Line 1571
11:35:43 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
11:35:43 PM #4 Text 0 File Writer.cpp, Line 134
Writer LITE-ON LTR-48246S running
11:35:43 PM #5 ISO9660GEN -11 File geniso.cpp, Line 4487
11:35:43 PM #6 Text 0 File Burncd.cpp, Line 3568
Turn on Track-At-Once, using CD-R/RW media
11:35:43 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 666
original CD pos #0 + 313721 (313721) = #313721/69:42.71
relocatable, CD pos for caching/writing not required/required, no patch infos
11:35:43 PM #8 Text 0 File DlgWaitCD.cpp, Line 202
Last possible write address on media: 359846 (79:59.71)
Last address to be written: 313720 (69:44.70)
11:35:43 PM #9 Text 0 File DlgWaitCD.cpp, Line 207
11:35:43 PM #10 Text 0 File DlgWaitCD.cpp, Line 1407
Recorder: LITE-ON LTR-48246S;
CDRW code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 18 01 (LI 97:24.01), 3: 4F 3B 48 (LO 79:59.72)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
11:35:43 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 818
Prepare recorder LITE-ON LTR-48246S for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 642807808
11:35:43 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 846
Removed 2 run-out blocks from end of track 1.
11:35:43 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 666
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 313719 blocks [LITE-ON LTR-48246S ]
11:35:43 PM #14 Phase 24 File dlgbrnst.cpp, Line 1571
Caching of files started
11:35:44 PM #15 Phase 25 File dlgbrnst.cpp, Line 1571
Caching of files completed
11:35:44 PM #16 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 48x (7,200 KB/s)
11:35:44 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
11:35:44 PM #18 Text 0 File Mmc.cpp, Line 17050
Set BUFE: supported -> ON , SMART-BURN : ON
11:35:49 PM #19 SCSI -500 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02680000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
11:35:49 PM #20 CDR -500 File Writer.cpp, Line 342
SCSI/IDE Command aborted
11:35:50 PM #21 Text 0 File ThreadedTransfer.cpp, Line 222
11:35:50 PM #22 Text 0 File ThreadedTransfer.cpp, Line 216
11:35:54 PM #23 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
11:35:54 PM #24 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
11:35:54 PM #25 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 48x (7,200 KB/s)
11:35:54 PM #26 Text 0 File Scsicmd.cpp, Line 402
Existing drivers:
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0307 built by: WinDDK, size=20224 bytes, created 11/13/2002 3:10:00 PM (Adapter driver for rec)
Registry Keys:
Thanks in advance!
kab
Re: problem w/ Nero 5.5 and Liteon 48x24x48
Postby dodecahedron on Sat Feb 01, 2003 3:05 am
hmm...strnage...it's not clear if you have DMA enabled.
kab wrote:DiskPeripheral : WDC WD800JB-00CRA1 17.0 nvidesm Port 0 ID 0 DMA: ?
i suggest you make sure it is.
check out the FAQ:
