Problem in CloneCD 4.3.X.X
Postby pranav81 on Thu Dec 04, 2003 3:37 am
Hi guys,
I normally dont use CloneCD as I dont copy a lot of CD's.So I was using CloneCD 4.2.0.2 for all these days.Yesterday I downloaded the latest version and installed it.It removed the Elby version and installed the Slysoft version and asked for a restart.I restarted and then tried to write a image of VCD which was taken by 4.2.0.2.When the actual writing process started,the computer shut down as if I had selected the shut down option from the start menu.The version installed was 4.3.1.9.I asked a friend of mine and he had 4.3.1.7.I got it and installed after removing and restarting the previous version.But again same problem of shut down occured.Thanks god I was using RW this time.
I removed the current install and installed 4.2.0.2 again.This time the CD was written without any problems from the same image file.
I have Windows XP SP1,latest Nero 5.5,Roxio 6 Plat.
Waiting for some replies on this topic,
::Pranav::
pranav81
Postby Han on Thu Dec 04, 2003 6:01 am
I made a coaster with 4.3.x.x, but never with 4.2.0.2. :-?
Han
CD-RW PiMP
Postby dodecahedron on Thu Dec 04, 2003 8:36 am
i'm sticking with 4.2.0.2 in the meanwhile.
Postby pranav81 on Fri Dec 05, 2003 10:17 am
Hi guys,
But why is the system turning OFF automatically when the burning begins?And how does 4.2.0.2 works without any problems?
Waiting for some replies,
::Pranav::
pranav81
clonecd 4.2.0.2
Postby agnost on Fri Dec 05, 2003 11:13 pm
Where do I get a usable copy of 4.2.0.2. I want to make a few 'backup' copies of a few games and am unable to get anything to work. I would love a copy of the above version (including a working password), however, have had no joy. Any help appreciated from a Newbie. :wink:
agnost
