Problem burning CD image with WinOnCD 5...
Postby damon on Sun Feb 02, 2003 1:32 pm
I make an image using WinOnCD and then i try to burn it. In the begining i receive the error massage from the software:
rror 00000200:75c82608 writing block 000009c0 in Disc 01 Copy 01, Track 01
BID: 0004e4e3 BOD: 000009c0
The device PHILIPS CDD6911 [B1.0] at han 3, id 1, lun 0 reported an error:5, 26 08
please check the manual of the device, that triggered the error.
GRI_WriteBlocks
#Track list#
00: D0 T1 CD-XA DM 00 SC 0 0004e4e3 CD Image,
---> RAW|OTF|PREGAP|OVRLEN|
---> Img:
P: 00:00:00
#CDRAL/CDRTC Info:#
ASPI DLL: CDRAL.DLL
CDR Helper DLL: CDRTC.DLL
CD-ROM drives:
Drive F: (3:0:0)
Drive G: (3:1:0)
#Current Recorder#
PHILIPS CDD6911 at Host 3 ID 1 LUN 0 - PHILIPS CDD6911 B1.0
F1:84bf0f7f F2:00000477 S:02222288 B:00000800
D:\Program Files\Roxio\WinOnCD\GRI_MMC.DLL Version 3.70.307
#Disc Options#
CLSDSC|DAO|
SizeReq: 71:16:39, WritePos 00:00:00
Speed: 24, Copies: 01
#Disc in Recorder#
Disc Type: CD-R, unknown Disc size
A0: ff current LO: (00:00:00), Outermost LO: (79:57:72), NRA: (00:00:00)
1 Sessions (0 finished), 0 Tracks
#Dirs#
ImgDir: C:\RoxioTmp
TempDir: C:\RoxioTmp
This massage apears with CD-R and CD-RW. Then I extract the files from image file with winISO and burned successful. I have no problems burning files from Hard Drive or copy CD. What is the problem?[/quote]
damon
Postby Gary Kokkin on Mon Feb 03, 2003 10:20 am
Winoncd 5 is very "light" in installation and more fast in burning CDrs from HD for DATA backup purposes,than other burning software.....but there are some bugs on it !
1) "Doesn't like" some brands or recorders ! even installed Service packs .
Maybe leave it in original condition. Use Aspi drivers 4,6
2) It hasnt reliable Audio ripping at all ,many errors
3) Doesn't easy work image files ,so must use other program ,a very good one is Discjuggler...
4) Try make image directory in "C:\windows\temp" with deletetion every time finished Winoncd
5) Avoid have Nero and Winoncd in same OS
Personally test , burn 700MB CDR (TY) at 1':45'' with Liteon 48125W !!
Gary Kokkin
Postby Han on Mon Feb 03, 2003 12:45 pm
Well, every burning application has bugs.
1. Service Packs usually don't add support for new devices. You have to apply a new uniDRV driver pack. Installing an ASPI is not recommended as it confuses the one included.
2. WinOnCD relys on the drive. If it does DAE with errors, lower DAE speed or use a third party program like Exact Audio Copy and enable Secure mode...
3. It supports only its own C2D images and true ISOs.
5. These two work fine together. Just don't run them at the same time. :wink:
Note that WinOnCD starts a time countdown after lead-in is finished and stops when lead-out starts. So add at least 30 seconds and you'll get a more appropriate burn time.
Han
CD-RW PiMP
Postby Gary Kokkin on Tue Feb 04, 2003 8:39 am
Han wrote :
"Note that WinOnCD starts a time countdown after lead-in is finished and stops when lead-out starts. So add at least 30 seconds and you'll get a more appropriate burn time."
I also have used stopwatch...burning in "create multissession CD" mode Leadin-out is total 5-10sec .
"Installing an ASPI is not recommended as it confuses the one included."
If use different burn software combination ,sometimes need .In my PC installation ,CDRW drive not working eg if dont install general Aspi drivers CDrwin (it's own drivers included too) not work !
Gary Kokkin
Postby Spazmogen on Thu Feb 06, 2003 4:28 pm
I can't get WinOnCD 5 PE to work well either.
I can make VCD & SVCD, but I can't copy an audio disc, nor can I compile and burn one.
The whole program hangs about 10 seconds into the burn.
XP Home SP1
256mb PC133
1GHZ P3 (not over clocked).
Soyo MB
I installed EZ CD 4 and it works fine (circa 1998/1999 too).
