Antec Performance Series case w/ 300 Watt Antec 303xp PS
Asus MB w/ Athlon 2000xp
512 MB Micron DDR
Gainward Geforce 3 Ti 200
SoundBlaster Audigy
PCI USB 2.0 card
PCI 100mb Network Card
Promise ATA100 PCI card
40 GB WD 7200 rpm 8mb HD
40 GB IBM 7200 rpm HD
Pioneer 16x DVD 106s
Lite-ON 52x24x52 burner (I killed my BTC 2 days ago flashing it)
Zip Drive (still need it about once a year Im afraid)
Floppy
5 Vantec Stealth 80mm case fans
Volcano 9 HS w/ adjustable 80mm fan
Question is this... At what point does one need a PS greater than 300w?? I haven't had any problems yet, but it just seems like I keep adding stuff
![:)](http://cdrlabs.com/forums/images/smilies/icon_smile.gif)
And second question. I have tried really hard to eliminate as much noise as possible from my fans and I am almost there, but the HS/fan on my video card is just too high pitched for me... Anyone have a suggestion as to a quieter solution. The Vantec Stealth Case Fans are really quiet as well as the Volcano 9 HS set on a low RPM..
Thanks!!
Jason
