Nero or Easy CD Creator
Postby Albinoni on Fri Oct 10, 2003 12:20 pm
What would your choice be, Nero or Easy CD Creator, and how do you compare the both of them, is Nero more powerful.
I've heard of quite a few people who've used Easy CD Creator and have had lots of problems with it. Also can Nero do more than Easy CD.
Well for me its Nero, hands down.
Albinoni
Postby CDRecorder on Fri Oct 10, 2003 4:22 pm
Congrats on 100 posts, Albinoni! :D
My favorite is Nero 5.5, but I currently use Nero 5.5, Easy CD Creator 5.3, NTI CD-Maker 2000 5.x, and WinOnCD 5.x Power Edition. Nero definitely has the best CD-burning features out of all of them. :D
Postby pranav81 on Sat Oct 11, 2003 2:49 pm
Hi,I normally use Easy CD Creator for burning normal CD's.I just use Nero 5.5 to burn overburn CD's.Roxio has added overburn support but I havent overburned a single CD with Roxio ECDC 6.
See ya later,
::Pranav::
pranav81
Postby pranav81 on Tue Oct 14, 2003 3:33 pm
Hi guys,I overburned a CD with ECDC 6.I must say that it aapers to be more easy than Nero.The CD I used was from Prodisc Technology CD-R 700 MB.I made a compilation of 711 MB and checked the overburning capacity of the CD-R with Nero CD-DVD Speed 2.02.It stated the overburn capacity as 718 MB.
But when the burning completed the tray was ejected and again pulled in,which never happens when the CD is burned normally with Roxio.The CD was read without problems in the CD-Writer and CD-ROM.
See ya guys later,
::Pranav::
pranav81
