Picked up a Memorex 525g 18x today UPDATED, Scans added
Postby Dartman on Sun Mar 04, 2007 4:35 pm
Staples has a sale on the Memorex this week and Ian said the one he got was a LG h22n so I went down and picked one up to see. Yup, appears to be a 22n according to the review pictures and what I just picked up. Just put it in my external bay and tried to write a Sony TYG03 disk at 18x but the firewire crapped out at just over 17x. Have to do more testing but so far appears promising.
So if anyone wants to test drive a LG 18x and doesn't mind paying 50 for a Memorex box with software and cables etc included this might be a good deal for some of you. I'll try and post a few results later after I get it dialed in, PC is busy doing some other burns right now that will take a bit.
Postby Wesociety on Sun Mar 04, 2007 6:42 pm
Nice. A new addition to the Dartman burner family.
Let's see a few scans when you have a chance ;)
Postby Dartman on Sun Mar 04, 2007 6:56 pm
Yep, Everybody wants disks from me today so been pretty busy, just the one test burn and a few reads with it so far.
Even with it dropping back at the end it did a 5:15 burn :D
Postby Wesociety on Sun Mar 04, 2007 7:03 pm
Dartman wrote:Even with it dropping back at the end it did a 5:15 burn :D
That's a respectable full DVD burn time. 8)
Postby Ian on Sun Mar 04, 2007 8:05 pm
Memorex or not, $50 is a good price for a retail drive.
On a semi-related note, has anyone been able to turn bitsetting off? It's on by default and CD Speed doesn't have any effect on the drive.
Scans
Postby Dartman on Sun Mar 11, 2007 2:35 pm
Got a bunch of scans done, range from really bad at the end to pretty good.
Best time at 18 so far was 5:04, average is about 5:14. Most of those CRC scan fine even with the bad spots at the end.
Office Depot MCC004
Variable batch quality at end, this was a good one at 18x
BENQ____DVD_LS_DW1655_BCIB_05-March-2007_lg good 18x burn.png (35.54 KiB) Viewed 6907 times
Sony branded 8x T02, would only burn at rated speed 8x
BENQ____DVD_LS_DW1655_BCIB_08-March-TYg02 with lg 1.02 at 8x.png (36.92 KiB) Viewed 6992 times
Sony TYG03 after lgh22 1.01 conversion, 18x
BENQ____DVD_LS_DW1655_BCIB_04-March-2007h22n 18x.png (38.7 KiB) Viewed 6905 times
The same batch of MCC004 at 18x, more typical results for this spindle on most drives
Postby Wesociety on Sun Mar 11, 2007 3:07 pm
Wow, that first 18x burn quality scan looks pretty good!
The 8x TY looks good, but the other 18x burns look like crap at the end.
But I suppose it is difficult to get good quality at 18x burn judging from most of the 18x burned disc quality scans I've seen, so 16x is probably the max to go with if you really don't want to jack up the disc quality at the end of a burn...
Postby Dartman on Sun Mar 11, 2007 4:21 pm
Yeah, between variably good to bad disk in the same spindle and a few with outer edge minor scratches it's hard to say what it really burns like sometimes.
The shop brand MCC disk are all over the map, most are not quite as bad as the awful one at the end even on my BenQ's, then you get the occasional really good disk outa the pack like the good burn.
IF they start giving out better firmwares the drive could be godlike I think but LG is known to be stingy with updates, and some of my 16x stuff only does 12x with it, though maybe after seeing the scans thats by choice on their part. Also my other drives burn that TY 8x stuff at 12 to 16 with excellent results...
Postby Ian on Sun Mar 11, 2007 4:56 pm
I take it you flashed it with the LG firmware? Do you know if 1.02 supports RITEKF1 at 16x or 18x?
Postby Dartman on Sun Mar 11, 2007 6:24 pm
I did the Dangerous Brothers flash, it ignores the drive type and just flashes it. I think it will now let you set the disk type too.
I'll have to try the Riteks, I think I have some, if the ones I just did where it it was 16x, I'll have to double check and report back.
Postby ala42 on Sun Mar 11, 2007 10:58 pm
Ian wrote:Do you know if 1.02 supports RITEKF1 at 16x or 18x?
My bet is 4x write speed :)
ala42
Postby Dartman on Sun Mar 11, 2007 11:03 pm
And the winner is....DING..DING..DING...4x, thank you for playing :lol:
Postby Ian on Sun Mar 11, 2007 11:43 pm
That's what I thought. It looks like Memorex got them to support RITEKF1 at 16x.. probably because that's what they're selling these days.
Postby Dartman on Sun Mar 11, 2007 11:49 pm
Well I don't have the OEM firmware on it now so who knows. I don't think they even list firmware on the Memorex site, pretty sure I checked in case they had the 1.02 in their version.
Postby Wesociety on Mon Mar 12, 2007 9:25 am
Dartman wrote:Yeah, between variably good to bad disk in the same spindle and a few with outer edge minor scratches it's hard to say what it really burns like sometimes.
Sounds like some B grade MCC004 that was sold off to a shop brand. :-?
4x on RITEKF1 with official LG firmware? Give us a freakin break LG !
I guess the best possible scenario would be if you could import the "special" strats from the Memorex firmware into the official LG firmware. I don't know if there is a tool out there that allows you to do that, just rambling here...
Postby ala42 on Mon Mar 12, 2007 10:02 am
Wesociety wrote:4x on RITEKF1 with official LG firmware? Give us a freakin break LG !
Who said the Memorex firmware allowed 16x burning on 16x Memorex branded RITEKF1 ?
ala42
Postby Ian on Mon Mar 12, 2007 10:19 am
ala42 wrote:Who said the Memorex firmware allowed 16x burning on 16x Memorex branded RITEKF1 ?
I don't have any of the Memorex brand, but the Ridata brand RITEKF1 works at 16x.
Postby ala42 on Mon Mar 12, 2007 10:54 am
On a Memorex 525g burner ?
ala42
Postby Ian on Mon Mar 12, 2007 11:07 am
Yup, on the Memorex.
Postby ala42 on Mon Mar 12, 2007 12:34 pm
Then get a Memorex firmware and I will copy the strategy to the LG firmware :)
ala42
Postby Wesociety on Mon Mar 12, 2007 12:34 pm
ala42: Memorex often gets customized strats added for their rebadged burners in order for them to be compatible with Memorex brand media.
Sometimes these strats don't show up in the official non-rebadged firmwares, as is the case in this scenario.
Postby Ian on Mon Mar 12, 2007 1:21 pm
I'm surprised they didn't add 18x write support for any of their media.
Postby Wesociety on Mon Mar 12, 2007 2:40 pm
Ian wrote:I'm surprised they didn't add 18x write support for any of their media.
Now that would REALLY be pushing it for Ritek 16x stuff.
Some of the better CMC stuff could probably handle 18x burning okay.
Postby Dartman on Tue Mar 13, 2007 12:02 am
It barely wrote it at 4x OK, was a good burn but a bit spikey in spots. Trying not to buy the crap store brands anymore. The closing CompUSA here has a TON of MIJ Sony 8x media last time I checked but they wanted 30 a spindle, not going to spend that much, I haven't been back since. I don't think they have any firmware posted for the 525g yet, maybe the Dangerous Brothers might have it hidden somewhere, didn't really think about backing up the old one before upgrading.
Maybe Ian can post his if theres a way to save it and we can play :)
Postby Wesociety on Tue Mar 13, 2007 10:27 am
Dartman wrote:It barely wrote it at 4x OK, was a good burn but a bit spikey in spots.
In Riteks' defense, it is not uncommon for high speed media to burn poorly at slow speeds, or in this case, probably without any type of proper calibration/optimization from LG.
Dartman wrote:I don't think they have any firmware posted for the 525g yet, maybe the Dangerous Brothers might have it hidden somewhere, didn't really think about backing up the old one before upgrading.
Doh! I'm sure TheDangerousBros would have liked to have been given this fw. :)
