the wrong format
the wrong format
Postby coonsanders on Wed Sep 20, 2006 4:37 pm
hi
maybe its in the format for the nero 6 soundtrax.i put line in in the audio
in put line but it might be wrong.any ideas?
coonsanders
coonsanders
the wrong format
Postby margrave on Wed Sep 20, 2006 6:39 pm
What is in the wrong format ? You need to describe your problem more clearly to get any help...
margrave
the wrong format
Postby coonsanders on Wed Sep 20, 2006 6:46 pm
hi
i making cds from lps and 78s.when using the nero 6 soundtrax should
i use line in,wave,auxililiry,or s/pif formats.line in has worked ok so far
but ive been haveing a problem with the soundtrax so i thought another
format would be better.thanks
coonsanders
coonsanders
Postby hoxlund on Wed Sep 20, 2006 10:17 pm
line in/aux in is the same thing, just different port
same 1/8 jack input into computer
spdif should give you better results, right?
the wrong format
Postby coonsanders on Wed Sep 20, 2006 10:45 pm
hi
im not sure what s/pif in is used 4?what is it used 4??
coonsanders
coonsanders
Postby Justin42 on Thu Sep 21, 2006 1:37 pm
Does your turntable have an RIAA amplifier built in? If not, you MUST have an RIAA amp in line, and ground your turntable, to get acceptable results. Radio Shack sells low-end ones for around $30.
Otherwise, check your turntable manual to see if it has an RIAA amp and if you can turn it on and off. Be sure it is on.
Line in is the ONLY correct option.
SPDIF in is a digital format. you will never find a turntable that will support it.
