LG GSA-H10N Quickie Preview
Postby Ian on Fri Apr 14, 2006 10:26 pm
LG hooked us up with their new Super Multi drive, the GSA-H10N. Since there isn't a lot of info on the web, I figured I'd post some screenshots and do a few quick tests.
LG GSA-H10N InfoTool.jpg (80.19 KiB) Viewed 12372 times
LG GSA-H10N DIP 2.jpg (70.63 KiB) Viewed 12395 times
LG GSA-H10N Bitsetting.jpg (42.02 KiB) Viewed 10160 times
Postby Ian on Fri Apr 14, 2006 10:28 pm
Did I mention I also have some of Maxell's 12x DVD-RAM media? Works great too.
More to come..
LG GSA-H10N CD Speed DVD-RAM Write Quality.jpg (100.5 KiB) Viewed 10097 times
LG GSA-H10N CD Speed DVD-RAM Write.jpg (100.38 KiB) Viewed 10090 times
Postby Ian on Fri Apr 14, 2006 11:07 pm
Who needs an 18x DVD writer. This thing is smoking fast when writing to DVD+R and DVD-R media. My only real beef is the high jitter rate in the beginning. Hopefully LG can fix this in the next firmware update.
LG GSA-H10N CD Speed DVD-R Read.jpg (96.67 KiB) Viewed 10008 times
LG GSA-H10N CD Speed DVD-R Write Quality.jpg (105.37 KiB) Viewed 10007 times
LG GSA-H10N CD Speed DVD-R Write.jpg (98.33 KiB) Viewed 9992 times
Postby Ian on Fri Apr 14, 2006 11:10 pm
And then you have DVD+R media...
I'll post some results with DL media this weekend. If you have anything else you'd like me to try, just ask. I'll try my best.
LG GSA-H10N CD Speed DVD+R Read.jpg (96.68 KiB) Viewed 9906 times
LG GSA-H10N CD Speed DVD+R Write Quality.jpg (107.54 KiB) Viewed 9894 times
LG GSA-H10N CD Speed DVD+R Write.jpg (97.89 KiB) Viewed 9887 times
Postby [buck] on Sat Apr 15, 2006 1:01 pm
You know, that jitter is so rediculously high that even what are usually unpicky players will start having troubles. It almost makes LiteON look good.
I'd have a hard time recommending this drive without seeing this jitter problem fixed.
Postby Scour on Sat Apr 15, 2006 6:45 pm
Nice :)
Low PIF, good DVD-RAM-writing @12x
But buck is right, this jitter do not look great
Postby ItalianJob on Mon Apr 17, 2006 4:43 am
12X DVD-RAM =P~
Very impressive burn time... my Ricoh DVD+RW 8X are burned in 9mn with my LG 4166.
PS : is H10A@H10N possible (with a working 12X DVD-RAM feature) ?
ItalianJob
Postby dodecahedron on Mon Apr 17, 2006 4:48 am
any idean when the drive, and the media, will be available on the market ?
also, this Maxell's 12x DVD-RAM, who is it made by? is it Maxell's own media?
i presume: single sided, non-cartridge type DVD-RAM, right?
Postby Ian on Mon Apr 17, 2006 10:03 am
I'm not sure about the H10A@H10N. What chipset does the H10A use?
The H10N should be shipping soon as we recieved a retail unit and not an engineering sample.
As far as the media goes, it's Maxell's own. And yeah, its single sided, non-cartridge.
Postby Scour on Mon Apr 17, 2006 11:09 am
This writer uses a Renesas, i guess? 16x P-CAV-writing
Postby dodecahedron on Mon Apr 17, 2006 11:11 am
any info on it on any of LG's websites ?
last i checked and looked for H10 and H20 variants, i only found some in LG Germany's website: H10A and H20L
GSA-H10A
GSA-H20L
from what i can tell they're very similar, major (only?) difference is LighScribe on the H20L.
Postby dolphinius_rex on Mon Apr 17, 2006 12:07 pm
dodecahedron wrote:any idean when the drive, and the media, will be available on the market ?
Either made by Maxell or Optodisc... currently I don't know if there is a way to tell them apart (Optodisc OEM Maxell DVD-RAM, and Maxell's own DVD-RAM).
Postby dodecahedron on Mon Apr 17, 2006 12:26 pm
Scour wrote:This writer uses a Renesas, i guess? 16x P-CAV-writing
yes, according to this topic @ cdfreaks:
http://club.cdfreaks.com/showthread.php?t=174602 (post #10)
Postby Scour on Mon Apr 17, 2006 1:06 pm
dodecahedron wrote:yes, according to this topic @ cdfreaks:
Thanks, dodecahedron :)
Postby Ian on Mon Apr 17, 2006 2:30 pm
Does anyone have the JJ11 firmware handy? All the links I've found to it no longer work.
Postby [buck] on Mon Apr 17, 2006 2:59 pm
There's GOT to be a way to tell them apart.. be it serials or physical characteristics. I can't see Optodisc being able to make a physical identical disc at Maxell, unless Maxell literally dumped all of their own equipment on Optodisc's doorstep.
It's just nobody's researched this enough, I suspect!! :D
Postby dolphinius_rex on Mon Apr 17, 2006 4:54 pm
Well, it's really rather complicated as it turns out. Optodisc seems to be making DVD-RAM for both Maxell and Panasonic, although just about everything possible is being done to make it so that people can't tell, and there is also a lot of internal denial of it. Really, if Optodisc hadn't admitted to it in the past, we wouldn't even know for sure! :o
Postby Ian on Mon Apr 17, 2006 7:57 pm
Here's the JJ11 firmware thanks to ala42.
GSAH10N_JJ11.zip
GSA-H10N JJ11 Firmware
(1.48 MiB) Downloaded 1005 times
Postby MacClipper on Tue Apr 18, 2006 12:59 pm
Ian wrote:Here's the JJ11 firmware thanks to ala42.
ahem, so did you manage to flash the burner from JL10 (retail fw) to JJ11 (Jap fw)? AFAIK, the stock flasher isn't cross flashable betw. retail and Jap units.
anyway, my own findings so far.
http://forums.hardwarezone.com/showthread.php?t=1265351
MacClipper
Postby Ian on Tue Apr 18, 2006 1:17 pm
I haven't tried it yet MacClipper. I asked my contact at LG for the update as well. We'll see what he comes up with.
Postby ItalianJob on Tue Apr 18, 2006 1:57 pm
Ian wrote:I'm not sure about the H10A@H10N. What chipset does the H10A use?
H10A uses Renesas R8J32018FPV chipset.
Source : http://club.cdfreaks.com/showpost.php?p ... ostcount=9
And according to this thread ( http://club.cdfreaks.com/showthread.php?t=174602 ), H10N uses RENESAS R8J32018FPV too...
ItalianJob
Postby dodecahedron on Wed Apr 19, 2006 2:19 pm
maybe a bit off-topic, but does anyone have any idea when:
1. other drives will feature fast DVD-RAM (12x and up) ? NEC ? Pioneer ?
2. we will see 16x DVD-RAM ? this was promised quite a bit of time ago now. i'm thinking maybe 12x DVD-RAM will be short-lived and 16x come soon.
Postby ItalianJob on Wed Apr 19, 2006 3:58 pm
ItalianJob
Postby Scour on Wed Apr 19, 2006 5:34 pm
ItalianJob wrote:1- Panasonic SW-9587S : http://dvd-r.jpn.org/RAM12x/index.html
In Germany/Europe no Panasonic-drives avaible
Postby dodecahedron on Wed Apr 19, 2006 6:29 pm
yeah, that was already mentioned here:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=21082
i meant something more readlily available and with better writing quality than Panasonic :o like NEC or Pioneer ... maybe even Lite-On.
