problem w/ hp 640i
problem w/ hp 640i
Postby n00b on Thu Jan 05, 2006 1:55 am
ok, i have been backing up some movies with this drive and have had no problems using Memorex dvd+r dl media i got from staples.
anyway, recently i upgraded the FW to JS04, and got some Verbatim discs from Wally World, and now i get error msgs.
the process i use is to
1 rip w/ dvd decrypter
2 use dvd shrink to create .iso file
3 use recordnow 7 to burn .iso to dvd
i also downloaded Nero to see if it would work, and i burned another coaster :(
my thinking is that since i have only changed two variables those are my only options to change. how do i return back to the original FW for the drive?
from what i have been reading here, Verbatim discs are good.
maybe Walmart carries the cheap ones?
running my finger around the edge of the disc i can feel some roughness, and looking at it closer, it seems like glue seeping out.
anyway, if anyone can point me in the right direction.......
TIA
n00b
Postby hoxlund on Thu Jan 05, 2006 2:11 am
just curious as to why your using dvd decrypter to rip
you can save a step and just rip with dvd shrink
Postby n00b on Thu Jan 05, 2006 12:42 pm
thanks
did not know that!!
n00b
Postby dodecahedron on Thu Jan 05, 2006 3:58 pm
i would say: why not burn the ISO with DVD Decrypter ?
Postby hoxlund on Fri Jan 06, 2006 2:03 am
dodecahedron wrote:i would say: why not burn the ISO with DVD Decrypter ?
yes rip with shrink, burn with decrypter
Postby dolphinius_rex on Fri Jan 06, 2006 2:55 am
Deffinately avoid using Memorex DVD+RDL, at least for the moment. Memorex is getting low grade Ritek DVD+RDL for their brand, if you need to rule out crappy media as a cause. If you're going to burn a double layer disc, then stick with Verbatim until you've gotten the kinks worked out.
If you follow Bestbuy and CompUSA sales, 10pks of Verbatim DVD+RDL are often on sale for $20 USD. If you're in Canada, then NCIX.com and Blankmedia.ca have the 10pks on sale for $28-$30 CAD from time to time also.
Postby n00b on Sat Jan 07, 2006 3:13 am
thanks for the tips!!
downloaded IMGBURN and have had no problems
also updated DVDdecrypter
thanks again
n00b
Postby dodecahedron on Sat Jan 07, 2006 3:19 am
personally, i would rip with DVD Decrypter and burn with either Decrypter or ImgBurn (same author).
i use DVD Shrink only to shrink! :)
Postby hoxlund on Sat Jan 07, 2006 12:48 pm
i would use imgburn but it doesn't incorprate itself into dvdshrink like dvddecrypter does
and it probably never will
Postby dodecahedron on Sat Jan 07, 2006 12:59 pm
why not? ImgBurn is written by the same programmer as DVD Decrypter, and it's very similar to it (to ISO Write mode).
i'm sure it's not difficult to update DVD Shrink in such a way that it will burn using ImgBurn. it's only a question if the guy who wrote DVD Shrink will do it.
Postby hoxlund on Sat Jan 07, 2006 1:04 pm
yeah look at the last time shrink was updated, again unlikely
Postby dodecahedron on Sat Jan 07, 2006 1:32 pm
hoxlund wrote:yeah look at the last time shrink was updated, again unlikely
true.
