i am using latest version of NERO on a Hi VAl 16x dvd burner using memorex 16x DVD+R disks
and getting the following error around 10% burn
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero API version: 6.6.0.14
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 14d
Recorder: <DVDRW USB 16X> Version: A187 - HA 2 TA 0 - 6.6.0.14
Adapter driver: <> HA 2
Drive buffer : 2048kB
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV0813H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-104 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-ROM SC-140C atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-104 E: CDRom0
SAMSUNG CD-ROM SC-140C F: CDRom1
DVDRW USB 16X H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 247MB (253460kB)
Free physical memory: 116MB (119096kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
4.7.2005
NeroAPI
4:21:25 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
4:21:25 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
4:21:25 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
4:21:25 PM #4 SCSI -1196 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0A906600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x02
CDB Data: 0xFA 0x01 0x00 0x00 0x00 0x00 0x00 0x04 0x00 0x00 0xAA 0xFF
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x3A 0x02
4:21:25 PM #5 Text 0 File Reader.cpp, Line 127
Reader running
4:21:25 PM #6 Text 0 File Writer.cpp, Line 122
Writer DVDRW USB 16X running
4:21:25 PM #7 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
4:21:25 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3297
4:21:26 PM #9 ISO9660GEN -11 File geniso.cpp, Line 3297
4:21:26 PM #10 Text 0 File Burncd.cpp, Line 3230
4:21:57 PM #11 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2282607 (507:14.57, 4458MB)
4:21:57 PM #12 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO
4:21:57 PM #13 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: DVDRW USB 16X, Media type: DVD+R
Disc Manufacturer ID: PHILIPS, Media Type ID: C16, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
4:21:57 PM #14 Text 0 File DlgWaitCD.cpp, Line 445
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R DL.)
4:21:57 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2282608 (2282608) = #2282608/507:14.58
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2282608 blocks [DVDRW USB 16X]
4:21:57 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [DVDRW USB 16X] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4674781184, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2282608 | lead-out | 1 | 0x41 | 0x00
4:21:58 PM #17 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
4:21:58 PM #18 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
4:21:58 PM #19 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
4:21:58 PM #20 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 16x (22,160 KB/s)
4:21:58 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643
4:21:58 PM #22 Text 0 File Cdrdrv.cpp, Line 8821
Book Type: DVD+R (10), Part Version: 1
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: PHILIPS.
Media type ID: C16
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 50 48 49 4C 49 - 50 53 00 43 31 36 01 38 ...PHILIPS.C16.8
23 54 37 12 02 5A 6E 02 - B0 68 16 16 0B 0B 0A 0A #T7..Zn..h......
01 1D 1E 0C 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
4:21:58 PM #23 Text 0 File DVDR.cpp, Line 5583
Drive: DVDRW USB 16X
Book Type request [BTC]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
4:21:58 PM #24 CDR -1211 File DVDR.cpp, Line 4929
Book Type set to: DVD-ROM
4:21:58 PM #25 Text 0 File DVDPlusRW.cpp, Line 655
Start write address at LBA 0
4:26:11 PM #26 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x01380000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x12 0x91 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
4:26:11 PM #27 CDR -1135 File Writer.cpp, Line 311
Write error
4:26:11 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228
4:26:11 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222
4:26:32 PM #30 Text 0 File DVDR.cpp, Line 5583
Book Type request [BTC]: DVD+R
4:26:32 PM #31 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 16x (22,160 KB/s)
4:26:32 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
4:26:32 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.70a, size=20176 bytes, created 1/15/2005 3:31:30 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
TND is online now Edit/Delete Message
