Session fixation error
Postby Ulysses on Wed Mar 09, 2005 1:10 pm
Currently running NERO v6.6.0.8 on Win98SE (NO other burning software is installed).
Sometimes at random whenever i continue a multisession data CD writing to CD-R media (different brands of quality media) everything seems like its going to work, burns all the way to 100%, but then I get a message saying "Session fixation error/Could not perform fixation"! :o
NO problem burning to CD-RWs.
I put the disc back into my recorder and went to Nero's 'Disc Info' feature and it says 'Session is Open'... i tried BOTH options in the bottom left of the window ['Close Session' and 'Close Disc'] w/o any success: same 'Session Fixation Error' here too...! :-k
Only thing to do hereafter is to throw the CD away, its useless since i'm not able to read whats written to the disc.
i guess that a full Nero log file from the failed write attempt would help to diagnose the issue better:
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/02 16.03.58
ahead WinASPI: File 'C:\PROGRAMMI\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/04 17.35.34
Nero Version: 6.6.0.8
Recorder: <WAITEC STORM 52/3> Version: 1.25 - HA 1 TA 0 - 6.6.0.8
Adapter driver: <ESDI_506> HA 1
Drive buffer : 2048kB
CD-ROM: < 54X CD-ROM >Version: 4.16 - HA 1 TA 1 - 6.6.0.8
WAITEC STORM40 (Target 1, E: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
WAITEC STORM 52/3 (Target 0, F: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
54X CD-ROM (Target 1, G: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
WriteBufferSize: 24117248 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 127MB (130568kB)
Free physical memory: 0MB (44kB)
Memory in use : 100 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
9.3.2005
CD-ROM (ISO)
13.09.21 #1 Text 0 File Isodoc.cpp, Line 6172
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Continue multisession
Burning mode : TAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
13.09.22 #2 Text 0 File Burncd.cpp, Line 2868
WAITEC STORM 52/3
SafeLink activated
13.09.22 #3 Text 0 File Reader.cpp, Line 127
Reader running
13.09.22 #4 Text 0 File Writer.cpp, Line 122
Writer WAITEC STORM 52/3 running
13.09.22 #5 ISO9660GEN -11 File geniso.cpp, Line 3293
13.09.23 #6 Text 0 File Burncd.cpp, Line 3153
Turn on Track-At-Once, using CD-R/RW media
13.09.24 #7 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 271461 ( 60:21.36)
13.09.24 #8 Text 0 File DlgWaitCD.cpp, Line 271
13.09.24 #9 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: WAITEC STORM 52/3;
CDR code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13.09.24 #10 Text 0 File DlgWaitCD.cpp, Line 433
13.09.24 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 162433 (162433) = #162433/36:5.58
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 162431 blocks [WAITEC STORM 52/3]
13.09.24 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [WAITEC STORM 52/3] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 332969984, ISRC ""
DAO layout:
108879 | lead-in | 0 | 0x41 | 0x00
108879 | 2 | 0 | 0x41 | 0x00
109029 | 2 | 1 | 0x41 | 0x00
271462 | lead-out | 1 | 0x41 | 0x00
13.09.24 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 2. Length: 162433 -> 162431.
13.09.24 #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
13.09.25 #15 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
13.09.25 #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
13.09.25 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (2.400 KB/s)
13.09.25 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #109029
13.09.25 #19 Text 0 File Mmc.cpp, Line 21235
Set BUFE: SafeLink -> ON , Adapt writespeed to disc : ON
13.11.44 #20 Text 0 File ThreadedTransfer.cpp, Line 228
13.11.48 #21 Text 0 File Mmc.cpp, Line 15908
<WAITEC STORM 52/3 > start Close Session
13.11.59 #22 SCSI -1093 File Cdrdrv.cpp, Line 1181
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x02 0x00
13.11.59 #23 CDR -1093 File ThreadedTransferInterface.cpp, Line 1288
No seek complete
13.11.59 #24 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1288
Could not perform Fixation
13.11.59 #25 Text 0 File Mmc.cpp, Line 15908
13.12.32 #26 SCSI -1176 File Cdrdrv.cpp, Line 1181
Sense Code: 0x72
Sense Qual: 0x00
0x00 0x00 0x00 0x00 0x72 0x00
13.12.32 #27 CDR -1176 File ThreadedTransferInterface.cpp, Line 1288
13.12.32 #28 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1288
13.12.32 #29 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 16x (2.400 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 05/05/99 22.22.00
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 11/03/02 10.55.38
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 05/05/99 22.22.00
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 05/05/99 22.22.00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 05/05/99 22.22.00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69574 bytes, created 05/05/99 22.22.00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 05/05/99 22.22.00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 05/05/99 22.22.00 (Adapter driver for rec)
Registry Keys:
As always, would appreciate any help or advice. TIA
"Houston, we've got a problem..."
(Jim Lovell, Apollo 13)
Ulysses
Postby CCampbell on Thu Mar 10, 2005 9:28 am
Hi Ulysses,
You are getting a 'No Seek Complete' error message and this is 95% of the time caused by hardware. It's usually one of the following issues...
1) Poor Media
2) Old Firmware
3) Dust, smudges, or scratches on the media
4) Dust on the Optical head of the recorder
5) Poor Power to the recorder
6) A recorder that is in need of service
Below is an exerpt from your log file:
Sense Code: 0x02
Sense Qual: 0x00
No seek complete
Postby Ulysses on Thu Mar 10, 2005 10:02 am
Hi CCampbell, thank you for these precise details...maybe time for a new model drive... :cry:
Ulysses
Postby CCampbell on Thu Mar 10, 2005 11:19 am
I would recommend trying to clean the Optical head before you go spending any more 'cash'. This works quite often.
Regard,
Postby Ulysses on Thu Mar 10, 2005 12:58 pm
hmmm...guess i've to dismantle the whole drive, that's my problem... :oops:
Ulysses
Postby dodecahedron on Fri Mar 11, 2005 1:28 am
or you could try using one of those CD-Cleaner CDs that have a little brush on the CD and it cleans the lens. though they're generally not recommended, it might be better than taking apart your drive...
Postby CCampbell on Fri Mar 11, 2005 5:01 am
And sometimes just grabbing a can of compressed air and carefully blowing in the drive with it will do the trick.
But if that fails, and the drive is out of warranty, I would open the drive up and use an Anti-Statick cloth, or one of those Camera Lens cleaning cloths to gently wipe off the optical head. And use compressed air to clean the rest of the inside of the drive.
P.S. Those CD Cleaner CD's have the potential of the brushes 'scratching' the optical head. But they have been known to do the trick, but I would ont use it that often.
