Burning Software with CD protection?
Postby mon0307 on Tue Aug 10, 2004 6:10 am
hi guys!. Anyone here knows a burning software that has a cd protection feature? Thanks!
mon0307
Postby pranav81 on Tue Aug 10, 2004 9:03 am
No protection that cannot be cracked.
There is a password protection if you use a Plextor and use Plextools.
::Pranav::
pranav81
Postby pika2000 on Tue Aug 10, 2004 6:50 pm
Try this: http://www.cd-lock.com/
They have a trial version. It's encryption + password system. I've been using this for my important data. The best thing is you can use the resulting CD with any PC without having to install any program. The executable is in burned along on your CD.
pika2000
Postby pranav81 on Wed Aug 11, 2004 8:27 am
Sounds like a cool software.I will check it out.
::Pranav::
pranav81
