- Code: Select all
http://www.plextor.co.jp/support/firmware/PX708A_102.exe
MadBurner wrote:Here's a direct link to the new firmware. No changelog was available at the time of this posting.
- Code: Select all
bobmitchell wrote:Did my first test with 1.02. Seems that using TDK 4X media used to take 8:20 or longer. Now the burn finishes at 7:29 and writing the lead out takes another :30 so total is 7:59. It burned 6X for the first 18% of the burn...then never lower than 8X the remainder...where in the past...used to slow down to 4X around 97%. Better. One minor quandry...every time I flash the drive...the first disk I write only writes at 4X. I have to finish...reboot and never does it again...funky!
Bob
Bob
aviationwiz wrote:Next few burns, can you watch it carefully, I want to see exactly how this thing works, so far so good, but I want a few more burn tests before I upgrade.
bobmitchell wrote:Good to know...I'll try that. Also the answer to the Nero question...still using 5.5.10.42....the only version I can rely on. I tried 6.0.0.15 and found that joliet was not available on DVD Movie burns...
Bob
Bob
bobmitchell wrote:The US Site is ALWAYS last to post it....never sure why!
Bob
PX-708A/UF V1.02
* Fixed Bugs: Some drives cannot read DVD+RW media that was recorded on PX-708A.
* Some drives cannot capture audio from US CD-RW media that was recorded on PX-708A.
* Writing sometimes fails on DVD-R/RW media using Nero.
* Re-format CD-RW media with Roxio's Drag to Disc sometimes fails.
* The first session of a multisession disc that was recorded with Nero cannot be read.
* Added: Support for 3.9GB DVD-R media.
* Improvements: Write performance for 4x DVD+R at 8x writing.
* Write performance for DVD-R media.
* Write performance for DVD-RW media.
* Support for newer CD-R media.
* Improved Buffer Control routines.
