by tazdevl on Wed Oct 08, 2003 10:35 pm
Try Nero 60011 and Nero 551042.
If you google, should be able to find a place to download. Or you can try
www.filemirrors.com
Plextools doesn't come with the drive, you need a previous version before you can install it. It's available on most file sharing networks or you can try the Plextor forum on
www.cdfreaks.com
I wouldn't use RW as a basis to determine how well the drive burns discs. I've always had issues with RW discs, regardless of the drive (both CD and DVD).
RIG:
