PLEXTOR 504A and NEC ND-1100A Bit Setting?
Postby jnesbitt on Wed Apr 16, 2003 10:48 pm
I have a NEC ND-1100A and the DVD+RW’s I burn will not play on my older home player. I have researched this and many people with my exact home DVD player solved their problem by changing the bit setting or mode of the disk. Specifically, they used a peice of software call DVDBitsetter.
http://dvdplusrw.org/resources/bitsettings_pc.html
However, the software told me that it works with all burners EXCEPT NEC and Sony.
Here is my question; do you think it will work with the PLEXTOR? As mentioned in Ian's article this drive is based on the NEC.
I have contacted NEC, Plextor, Nero, Roxio and DELL and nobody has ever heard of the “bit setting”. Even though it is a new option in the Nero software the tech guy didn’t know what it did.
Thank you for any help, I am desperate. I only have a few days left to return the NEC and get the Plextor.
jnesbitt
Postby Boone on Thu Apr 17, 2003 11:24 am
If you can't find the answer soon, I'd strongly suggest returning the NEC, getting the Plextor (assuming it has a return policy as well) and try that. If they both fail... home DVD Players aren't too expensive anymore.
Boone
