Pioneer Releases 1.28 Firmware For DVR-112 & DVR-212 Series
Postby Ian on Wed Nov 12, 2008 1:19 pm
Pioneer Japan has released the 1.28 firmware for its DVR-112 and DVD-212 series of drives.
http://wwwbsc.pioneer.co.jp/product-e/i ... 01r_e.html
Format erroe problem on WindowsVista DVD-RAM Full Format are solved.
DVR-212 - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
DVR-212D - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
DVR-A12LF - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
DVR-A12/DVR-112BXL/DVR-112DXL - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
DVR-112 - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
DVR-112D - http://wwwbsc.pioneer.co.jp/product-e/i ... W128EU.EXE
The list of supported media has also been updated:
http://wwwbsc.pioneer.co.jp/product-e/i ... 12_128.pdf
Re: Pioneer Releases 1.28 Firmware For DVR-112 & DVR-212 Series
Postby SithTracy on Thu Nov 13, 2008 4:36 pm
Thanks Ian... still using a DVR-212.
Postby Ian on Fri Nov 14, 2008 11:36 am
No prob. Its good to see that Pioneer is still updating their old drives. I wish other companies would do that.
Postby Bhairav on Wed Nov 19, 2008 8:06 am
Thanks, Ian. Any idea if this is compatible with MCSE?
Postby SithTracy on Wed Nov 19, 2008 9:57 am
Bhairav wrote:Any idea if this is compatible with MCSE?
If you are referring to ala42's MediaCodeSpeedEdit, yes it is. I modded my DVR-212D to a DVR-212 to add DVD-RAM support and bitsetting.
Postby HMR on Sun Nov 23, 2008 4:08 pm
Hi,
Having some problems w/ the 1.28 upgrade... getting read/write errors that previously didnt happen. Think it might be related to the new 1.28 firmware. Anyone know how to downgrade it back to 1.24?
Thanks,
Hmr.
HMR
Postby SithTracy on Sun Nov 23, 2008 9:08 pm
Un-rar the Pioneer firmware and use MediaCodeSpeedEdit to "LOAD" the firmware updater program (the exe file) and modify it like this diagram. And then save the file under a new name and use the new updater to load the older firmware.
Postby HMR on Sun Nov 23, 2008 11:09 pm
Hi SithTracy,
Thanks so much for the reply. I am new to flashing DVD drives so I hope this is not a dumb question. Basically, it sounds like you want to me to load the executable 'UPR12TD.exe into MCSE and check 'allow same to same flashing'. Then save the executable as different filename. Once I do that what I need to do to get firmware 'S0813001.124' (version 1.24) back into the DVD drive? Do I run 'UDR12TD.exe' manually from the command prompt? If so I need to set any command line parameters?
I apolize if these are dumb questions. I appreciate all you help. =)
Hmr.
HMR
Postby SithTracy on Mon Nov 24, 2008 7:12 am
Yes, you would run the renamed version manually from the command line. Just make sure it is in the same directory as the firmware file. No command line parameters are needed.
Postby ala42 on Mon Nov 24, 2008 8:06 pm
No need to start the patched flasher from the command promt, just double click it in windows explorer as usual.
ala42
