Pioneer a05 + Pioneer dvd-rw 2x media..help please..
Postby w3ndy on Sat Jan 18, 2003 4:07 pm
hi, i just bought a a05 and im trying to burn with veritas record now, i have updated fw and record now and it still doesnt let me burn at 2x =(
i have no idea what to do, does anyone also have this problem or is it just me ? i appreciate all the help i can get, thx.
w3ndy
Postby Viper on Sat Jan 18, 2003 9:32 pm
Got to use 2X media, heres were I got mine work great with teh A05 and are cost effective also......
http://www.qtccdr.com/product-detail.cf ... D2X&unit=N
Viper :)
Viper
Postby w3ndy on Sun Jan 19, 2003 1:33 am
well, i tried with 2x media from pioneer and i can only burn at 1x and i have updatet everything, its really odd =/
w3ndy
Postby Viper on Sun Jan 19, 2003 3:25 pm
w3ndy wrote:well, i tried with 2x media from pioneer and i can only burn at 1x and i have updatet everything, its really odd =/
Well make sure you have the updated firmware also, 1.21 I thinks its called. Do a search on google I am sure you can find it.
Viper
Viper
Postby boblx2 on Mon Jan 20, 2003 12:55 pm
I hope you have more luck with your A05 then I have had. The only media I found that will work at all (at any speed!) was the Ritek 4X media. It burned at 4X. All other media, with the exception of those Princo blue R/W discs, failed. I get a message that either says "insert media" or it burns a coaster. I am satisfied that it burns Ritek at 4X though that is why I bought it in the first place. But my firmware is 1.00 so maybe if I upgraded the firmware it would work with more media.
Good luck with it.........
Have fun.........Bob
boblx2
Postby w3ndy on Thu Jan 30, 2003 9:16 pm
uh, its a pain to find media for the a05 for sure, think i will return it and get another burner or something, does any of you guys happen to know a burner that _WORKS_ perfect =)
i am getting really pissed off at pioneer, crap burner imo., but thats just me..
thanks
/w3ndy
w3ndy
Postby boblx2 on Fri Jan 31, 2003 11:49 am
I would not return it. I just be sure to use Ritek 4X media with it. Burns like a champ! I think Princo media also works on it. I have some old Princo -R/W media and it works on the A05 so maybe other Princo media works too.
Ritek 4X media can be had from Hyper Micro for less then $2.00 a disc. That is hard to beat and every one of them work. I have never had a failure. I am sure Pioneer will clear this up soon anyway.
boblx2
I'VE GOT THE SAME PROBLEM
Postby sabujo on Sun Feb 02, 2003 8:02 am
pionner's own 2x dvd-rw only can be red in the recorder if burned at 2x. if it's burned at 1x or i use any other 1x brand it will read fine on other dvd-rom drives. 2x media from princo makes nice coasters though a tad expensive. i really want to give pionner a piece of my mind. i've spent a s**t load of money and time over this piece of crap. why oh why didn't i just waited another week and got me a sony wich i know for a fact has none of this issues? i'll defenitly return it asap. :evil:
to everything there's an end...
except for the sausage wich has two
sabujo
Postby boblx2 on Mon Feb 03, 2003 10:49 am
sabujo, don't think the Sony drive is a bed of roses either. I have both of them and while I would recommend the Sony over the Pioneer A05 I cannot get this one to burn at 4X on any kind of media with any version of firmware. However it will burn at 2.4 X or better on +R media and it works fine with -R on 1X or 2X. So it is the most useable of the two but not without problems. We have another Sony drive here that was purchased at the same time as mine and has 1.0f firmeware that will burn the DVD-ON version of Ritek 4X media at 4X. We are currently trying to disover the differences in the drives, setups, etc.
It does sound like you may have a bad drive. Although I do not use burners for reading so I am not sure how mine compare.
Good luck with it...............
boblx2
