Parallel Port tech question
Postby ryus on Sun Apr 06, 2003 1:57 am
What is the best mode to have your parallel port on?
ECP, Bidirectional, EPP ??
and whats the diff??
Thanks.
P4 3.0C, Abit IC7-MAX3, Antec True480W, Kingwin Aluminum case, 2X256 OCZ PC4000 Gold Edition,
Maxtor SATA 160GB, Maxtor 40GB ATA133
ATI 128mb Radeon 9800 Pro
Asus CD-S520, LiteON JLMS 166, Plexwriter48/24/48A, Pioneer 107
ryus
Postby vbl117 on Sun Apr 06, 2003 7:49 am
ECP is the latest mode ( so i think you should use it unless you have a very old printer ) . I don't know well the differences .
Perhaps you ll find some explanations there :
http://www.beyondlogic.org/
vbl117
Postby CDRecorder on Sun Apr 06, 2003 4:55 pm
I have my desktops on SPP (their default). The desktops are 1.5 and 3.5 years old. My printers are 8-10 years old (they still work!). Would it help them to use a better mode? Would it hurt to use a better mode? My laptop is on ECP (I think) but I have never used a parallel printer on it - only USB or networked printers.
Postby vbl117 on Sun Apr 06, 2003 6:52 pm
SPP is the oldest mode and it is the more compatible mode . Perhaps your printer would be able to use EPP mode ( i don't know well printers ) . I don't know if you could have a benefit and which benefit it could be . I don't think you could hurt your hardware ( i think in the worse case it could not work ) .
If you have still your manual you can check which is the mode recommanded for your printer . Else you can try to check it on manufacturer website .
vbl117
Postby CDRecorder on Mon Apr 07, 2003 12:09 am
Thanks vbl117! I'll give it a try!
Postby Inertia on Mon Apr 07, 2003 12:59 am
EPP (Enhanced Parallel Port) and ECP (Extended Capabilities Port) both have bidirectional capability which is only useful if your printer or other device supports it.
ECP also uses a DMA channel, which may be a disadvantage if free DMA channels are needed for ATAPI devices like burners and DVD-ROM's. The advantage of a DMA channel for a parallel port is marginal at best, so generally it is a safe bet to use EPP if bidirectional capability is required.
DMA channels have a major impact on the performance of ATAPI devices, so it is best to reserve DMA channels for use where performance is significantly improved.
Inertia
Postby blakerwry on Mon Apr 07, 2003 12:08 pm
I beleive ECP is supposed to be better for things like zip drives and EPP is suppsoed to be better for printing... this is just what I've heard.
blakerwry
