coolestnitish wrote:I think I will buy the 48x24x48 and flash it to the 52x. If we look at the model numbers of both the drives - LTR - 48246S and LTR - 52246S. The 6S at the back of the number looks like represents a MediaTek 6 Chip. So, they are probably using the same chip, then overclocking should make the 48 -> 52 with no extra strain on the drive.
Maybe you missed it, but dhc014 already told you that they use the same chipset. You can trust dhc014 when it comes to firmware - he knows what he is talking about and is arguably the resident firmware expert here. By the way, I seem to recall reading that the 6 at the end of the LiteOn model number does
not indicate a MediaTek 6 chipset, but rather the 6'th generation of LiteOn drives. So your reasoning was wrong but your conclusion happened to be right.
coolestnitish wrote:What about the RPMs? Do they change with the firmware flashing too?
Yes. As dhc014 said, "when you convert it to a Lite-ON LTR-52246S, it becomes one and has all of the same features." Once it is flashed, it
is a LTR-52246S with the exception of the label on the outside. So anything that applies to the LTR-52246S applies to the flashed drive.
