Optiarc DVD RW AD-7710H Firmware 1.V0
Postby ramkbala on Mon Mar 04, 2013 1:59 pm
Hi,
I use sony VPCEA45FG with Windows 7 Home Premium (64 Bit). It has Optiarc DVD RW AD-7710H Firmware 1.V0 DVD drive.
I Burned the backup of My OS in 3 DVDs. after that I did not write anything Using this DVD drive for more than 1 year.
Yesterday When I tried to write DVD Videos using Nero. It failed.
I tried using Imageburn. It showed the following I/O Error.
I/O Error
I-O Error.png (34.25 KiB) Viewed 27576 times
I saved the ImageBurn log file. I am not able to upload the file. So I pasted inline. Sorry for this.
I 21:19:54 ImgBurn Version 2.5.7.0 started!
I 21:19:54 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7600)
I 21:19:54 Total Physical Memory: 4,044,900 KB - Available: 1,928,044 KB
I 21:19:54 Initialising SPTI...
I 21:19:54 Searching for SCSI / ATAPI devices...
I 21:19:54 -> Drive 1 - Info: Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:19:54 Found 1 DVD±RW/RAM!
I 21:29:03 Operation Started!
I 21:29:03 Source File: E:\pappa\Slideshow\2013-03-03-235918.iso
I 21:29:03 Source File Sectors: 2,116,940 (MODE1/2048)
I 21:29:03 Source File Size: 4,335,493,120 bytes
I 21:29:04 Source File Volume Identifier: PHOTOS_VIDEOS
I 21:29:04 Source File Volume Set Identifier: PHOTOS_VIDEOS
I 21:29:04 Source File Implementation Identifier: UDF Image Creator
I 21:29:04 Source File File System(s): ISO9660, UDF (1.02)
I 21:29:04 Destination Device: [0:1:0] Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:29:04 Destination Media Type: DVD+R (Disc ID: MBIPG101-R05-01)
I 21:29:04 Destination Media Supported Write Speeds: 2.4x, 4x, 6x, 8x
I 21:29:04 Destination Media Sectors: 2,295,104
I 21:29:04 Write Mode: DVD
I 21:29:04 Write Type: DAO
I 21:29:04 Write Speed: 4x
I 21:29:04 DVD+R Reserve Track: No
I 21:29:04 Link Size: Auto
I 21:29:04 Lock Volume: Yes
I 21:29:04 Test Mode: No
I 21:29:04 OPC: No
I 21:29:04 BURN-Proof: Enabled
I 21:29:04 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 21:29:04 Book Type Setting: DVD+R
I 21:29:04 Filling Buffer... (80 MB)
I 21:29:06 Writing LeadIn...
I 21:29:19 Writing Session 1 of 1... (1 Track, LBA: 0 - 2116939)
I 21:29:19 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2116939)
W 21:39:09 Failed to Write Sectors 1202944 - 1202975 - Reason: Write Error
W 21:39:10 Retrying (1 of 20)...
W 21:39:10 Retry Failed - Reason: Write Error
W 21:39:10 Retrying (2 of 20)...
W 21:39:10 Retrying (3 of 20)...
W 21:39:10 Retrying (4 of 20)...
W 21:39:10 Retrying (5 of 20)...
W 21:39:10 Retrying (6 of 20)...
W 21:39:10 Retrying (7 of 20)...
W 21:39:10 Retrying (8 of 20)...
W 21:39:10 Retrying (9 of 20)...
W 21:39:10 Retrying (10 of 20)...
W 21:39:10 Retrying (11 of 20)...
W 21:39:10 Retrying (12 of 20)...
W 21:39:10 Retrying (13 of 20)...
W 21:39:10 Retrying (14 of 20)...
W 21:39:10 Retrying (15 of 20)...
W 21:39:10 Retrying (16 of 20)...
W 21:39:10 Retrying (17 of 20)...
W 21:39:10 Retrying (18 of 20)...
W 21:39:10 Retrying (19 of 20)...
W 21:39:10 Retrying (20 of 20)...
W 21:39:30 Retrying (21)...
W 21:39:30 Retry Failed - Reason: Write Error
W 21:39:31 Retrying (22)...
W 21:39:31 Retry Failed - Reason: Write Error
W 21:39:40 Retrying (23)...
W 21:39:40 Retry Failed - Reason: Write Error
W 21:39:43 Retrying (24)...
W 21:39:43 Retry Failed - Reason: Write Error
E 21:39:46 Failed to Write Sectors 1202944 - 1202975 - Reason: Write Error
I 21:39:47 Synchronising Cache...
I 21:40:09 Closing Track...
W 21:40:09 Close Track Failed! - Reason: Write Error
W 21:40:16 Retrying (1)...
I 21:40:24 Finalising Disc...
E 21:40:25 Failed to Write Image!
I 21:40:25 Exporting Graph Data...
I 21:40:25 Graph Data File: C:\Users\Ramki\AppData\Roaming\ImgBurn\Graph Data Files\Optiarc_DVD_RW_AD-7710H_1.V0_04-MARCH-2013_PM_09-29_MBIPG101-R05-01_4x.ibg
I 21:40:25 Export Successfully Completed!
E 21:40:25 Operation Failed! - Duration: 00:11:21
I 21:40:25 Average Write Rate: 3,837 KB/s (2.8x) - Maximum Write Rate: 5,580 KB/s (4.0x)
I 21:40:44 Operation Started!
I 21:40:44 Source File: E:\pappa\Slideshow\2013-03-03-235918.iso
I 21:40:44 Source File Sectors: 2,116,940 (MODE1/2048)
I 21:40:44 Source File Size: 4,335,493,120 bytes
I 21:40:44 Source File Volume Identifier: PHOTOS_VIDEOS
I 21:40:44 Source File Volume Set Identifier: PHOTOS_VIDEOS
I 21:40:44 Source File Implementation Identifier: UDF Image Creator
I 21:40:44 Source File File System(s): ISO9660, UDF (1.02)
I 21:40:44 Destination Device: [0:1:0] Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:40:44 Destination Media Type: DVD+R (Disc ID: MBIPG101-R05-01)
I 21:40:44 Destination Media Supported Write Speeds: 2.4x, 4x, 6x, 8x
I 21:40:44 Destination Media Sectors: 2,294,848
I 21:40:44 Write Mode: DVD
I 21:40:44 Write Type: DAO
I 21:40:44 Write Speed: 4x
I 21:40:44 DVD+R Reserve Track: No
I 21:40:44 Link Size: Auto
I 21:40:44 Lock Volume: Yes
I 21:40:44 Test Mode: No
I 21:40:44 OPC: No
I 21:40:44 BURN-Proof: Enabled
I 21:40:44 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 21:40:44 Book Type Setting: DVD+R
I 21:40:44 Filling Buffer... (80 MB)
I 21:40:46 Writing LeadIn...
W 21:40:46 Failed to Write Sectors 0 - 31 - Reason: Write Error
W 21:40:46 Retrying (1 of 20)...
W 21:40:47 Retry Failed - Reason: Write Error
W 21:40:47 Retrying (2 of 20)...
W 21:40:47 Retrying (3 of 20)...
W 21:40:47 Retrying (4 of 20)...
W 21:40:47 Retrying (5 of 20)...
W 21:40:47 Retrying (6 of 20)...
W 21:40:47 Retrying (7 of 20)...
W 21:40:47 Retrying (8 of 20)...
W 21:40:47 Retrying (9 of 20)...
W 21:40:47 Retrying (10 of 20)...
W 21:40:47 Retrying (11 of 20)...
W 21:40:47 Retrying (12 of 20)...
W 21:40:47 Retrying (13 of 20)...
W 21:40:47 Retrying (14 of 20)...
W 21:40:47 Retrying (15 of 20)...
W 21:40:47 Retrying (16 of 20)...
W 21:40:47 Retrying (17 of 20)...
W 21:40:47 Retrying (18 of 20)...
W 21:40:47 Retrying (19 of 20)...
W 21:40:47 Retrying (20 of 20)...
W 21:40:52 Retrying (21)...
W 21:40:52 Retry Failed - Reason: Write Error
W 21:40:53 Retrying (22)...
W 21:40:53 Retry Failed - Reason: Write Error
E 21:40:54 Failed to Write Sectors 0 - 31 - Reason: Write Error
I 21:40:54 Synchronising Cache...
W 21:40:57 User opted to skip the 'Close Track/Session/Disc' functions.
E 21:40:57 Failed to Write Image!
E 21:40:57 Operation Failed! - Duration: 00:00:13
I 21:40:57 Average Write Rate: N/A - Maximum Write Rate: N/A
I 21:41:31 Operation Started!
I 21:41:31 Source File: -==/\/[DISCOVERY IMAGE]\/\==-
I 21:41:31 Source File Sectors: 2,294,848 (MODE1/2048)
I 21:41:31 Source File Size: 4,699,848,704 bytes
I 21:41:31 Source File Volume Identifier: IMGBURN_DISCOVERY_IMAGE
I 21:41:31 Source File Volume Set Identifier: 2294848_SECTORS
I 21:41:31 Source File Application Identifier: IMGBURN V2.5.7.0 - THE ULTIMATE IMAGE BURNER!
I 21:41:31 Source File Implementation Identifier: ImgBurn v2.5.7.0
I 21:41:31 Source File File System(s): ISO9660
I 21:41:31 Destination Device: [0:1:0] Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:41:31 Destination Media Type: DVD+R (Disc ID: MBIPG101-R05-01)
I 21:41:31 Destination Media Supported Write Speeds: 2.4x, 4x, 6x, 8x
I 21:41:31 Destination Media Sectors: 2,294,848
I 21:41:31 Write Mode: DVD
I 21:41:31 Write Type: DAO
I 21:41:31 Write Speed: 4x
I 21:41:31 DVD+R Reserve Track: No
I 21:41:31 Link Size: Auto
I 21:41:31 Lock Volume: Yes
I 21:41:31 Test Mode: No
I 21:41:31 OPC: No
I 21:41:31 BURN-Proof: Enabled
I 21:41:31 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 21:41:31 Book Type Setting: DVD+R
I 21:41:31 Filling Buffer... (80 MB)
I 21:41:31 Writing LeadIn...
W 21:41:31 Failed to Write Sectors 0 - 31 - Reason: Write Error
W 21:41:31 Retrying (1 of 20)...
W 21:41:31 Retry Failed - Reason: Write Error
W 21:41:31 Retrying (2 of 20)...
W 21:41:31 Retrying (3 of 20)...
W 21:41:31 Retrying (4 of 20)...
W 21:41:31 Retrying (5 of 20)...
W 21:41:31 Retrying (6 of 20)...
W 21:41:31 Retrying (7 of 20)...
W 21:41:31 Retrying (8 of 20)...
W 21:41:31 Retrying (9 of 20)...
W 21:41:32 Retrying (10 of 20)...
W 21:41:32 Retry Failed - Reason: Write Error
W 21:41:32 Retrying (11 of 20)...
W 21:41:32 Retrying (12 of 20)...
W 21:41:32 Retrying (13 of 20)...
W 21:41:32 Retrying (14 of 20)...
W 21:41:32 Retrying (15 of 20)...
W 21:41:32 Retrying (16 of 20)...
W 21:41:32 Retrying (17 of 20)...
W 21:41:32 Retrying (18 of 20)...
W 21:41:32 Retrying (19 of 20)...
W 21:41:32 Retrying (20 of 20)...
W 21:41:36 Retrying (21)...
W 21:41:36 Retry Failed - Reason: Write Error
E 21:41:38 Failed to Write Sectors 0 - 31 - Reason: Write Error
I 21:41:38 Synchronising Cache...
I 21:41:40 Closing Track...
W 21:41:40 Close Track Failed! - Reason: Write Error
W 21:41:42 Retrying (1)...
I 21:41:44 Finalising Disc...
E 21:41:45 Failed to Write Image!
E 21:41:45 Operation Failed! - Duration: 00:00:13
I 21:41:45 Average Write Rate: N/A - Maximum Write Rate: N/A
I 21:42:01 Operation Started!
I 21:42:01 Source File: -==/\/[DISCOVERY IMAGE]\/\==-
I 21:42:01 Source File Sectors: 2,294,848 (MODE1/2048)
I 21:42:01 Source File Size: 4,699,848,704 bytes
I 21:42:01 Source File Volume Identifier: IMGBURN_DISCOVERY_IMAGE
I 21:42:01 Source File Volume Set Identifier: 2294848_SECTORS
I 21:42:01 Source File Application Identifier: IMGBURN V2.5.7.0 - THE ULTIMATE IMAGE BURNER!
I 21:42:01 Source File Implementation Identifier: ImgBurn v2.5.7.0
I 21:42:01 Source File File System(s): ISO9660
I 21:42:01 Destination Device: [0:1:0] Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:42:01 Destination Media Type: DVD+R (Disc ID: MBIPG101-R05-01)
I 21:42:02 Destination Media Supported Write Speeds: 2.4x, 4x, 6x, 8x
I 21:42:02 Destination Media Sectors: 2,294,848
I 21:42:02 Write Mode: DVD
I 21:42:02 Write Type: DAO
I 21:42:02 Write Speed: 4x
I 21:42:02 DVD+R Reserve Track: No
I 21:42:02 Link Size: Auto
I 21:42:02 Lock Volume: Yes
I 21:42:02 Test Mode: No
I 21:42:02 OPC: No
I 21:42:02 BURN-Proof: Enabled
I 21:42:02 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 21:42:02 Book Type Setting: DVD+R
I 21:42:02 Filling Buffer... (80 MB)
I 21:42:02 Writing LeadIn...
W 21:42:02 Failed to Write Sectors 0 - 31 - Reason: Write Error
W 21:42:02 Retrying (1 of 20)...
W 21:42:02 Retry Failed - Reason: Write Error
W 21:42:02 Retrying (2 of 20)...
W 21:42:02 Retrying (3 of 20)...
W 21:42:02 Retrying (4 of 20)...
W 21:42:02 Retrying (5 of 20)...
W 21:42:02 Retrying (6 of 20)...
W 21:42:02 Retrying (7 of 20)...
W 21:42:02 Retrying (8 of 20)...
W 21:42:02 Retrying (9 of 20)...
W 21:42:02 Retrying (10 of 20)...
W 21:42:02 Retrying (11 of 20)...
W 21:42:02 Retrying (12 of 20)...
W 21:42:02 Retrying (13 of 20)...
W 21:42:02 Retrying (14 of 20)...
W 21:42:02 Retrying (15 of 20)...
W 21:42:02 Retrying (16 of 20)...
W 21:42:02 Retrying (17 of 20)...
W 21:42:02 Retrying (18 of 20)...
W 21:42:02 Retrying (19 of 20)...
W 21:42:02 Retrying (20 of 20)...
E 21:42:05 Failed to Write Sectors 0 - 31 - Reason: Write Error
I 21:42:05 Synchronising Cache...
W 21:42:08 User opted to skip the 'Close Track/Session/Disc' functions.
E 21:42:08 Failed to Write Image!
E 21:42:08 Operation Failed! - Duration: 00:00:06
I 21:42:08 Average Write Rate: N/A - Maximum Write Rate: N/A
I 21:43:38 Operation Started!
I 21:43:38 Source File: -==/\/[DISCOVERY IMAGE]\/\==-
I 21:43:38 Source File Sectors: 2,294,848 (MODE1/2048)
I 21:43:38 Source File Size: 4,699,848,704 bytes
I 21:43:38 Source File Volume Identifier: IMGBURN_DISCOVERY_IMAGE
I 21:43:38 Source File Volume Set Identifier: 2294848_SECTORS
I 21:43:38 Source File Application Identifier: IMGBURN V2.5.7.0 - THE ULTIMATE IMAGE BURNER!
I 21:43:38 Source File Implementation Identifier: ImgBurn v2.5.7.0
I 21:43:38 Source File File System(s): ISO9660
I 21:43:38 Destination Device: [0:1:0] Optiarc DVD RW AD-7710H 1.V0 (D:) (ATAPI)
I 21:43:38 Destination Media Type: DVD+R (Disc ID: MBIPG101-R05-01)
I 21:43:38 Destination Media Supported Write Speeds: 2.4x, 4x, 6x, 8x
I 21:43:38 Destination Media Sectors: 2,294,848
I 21:43:38 Write Mode: DVD
I 21:43:38 Write Type: DAO
I 21:43:38 Write Speed: 4x
I 21:43:38 DVD+R Reserve Track: No
I 21:43:38 Link Size: Auto
I 21:43:38 Lock Volume: Yes
I 21:43:38 Test Mode: No
I 21:43:38 OPC: No
I 21:43:38 BURN-Proof: Enabled
I 21:43:38 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 21:43:38 Book Type Setting: DVD+R
I 21:43:38 Filling Buffer... (80 MB)
I 21:43:38 Writing LeadIn...
W 21:43:38 Failed to Write Sectors 0 - 31 - Reason: Write Error
W 21:43:38 Retrying (1 of 20)...
W 21:43:38 Retry Failed - Reason: Write Error
W 21:43:38 Retrying (2 of 20)...
W 21:43:38 Retrying (3 of 20)...
W 21:43:38 Retrying (4 of 20)...
W 21:43:38 Retrying (5 of 20)...
W 21:43:38 Retrying (6 of 20)...
W 21:43:38 Retrying (7 of 20)...
W 21:43:38 Retrying (8 of 20)...
W 21:43:38 Retrying (9 of 20)...
W 21:43:38 Retrying (10 of 20)...
W 21:43:38 Retrying (11 of 20)...
W 21:43:38 Retrying (12 of 20)...
W 21:43:38 Retrying (13 of 20)...
W 21:43:38 Retrying (14 of 20)...
W 21:43:38 Retrying (15 of 20)...
W 21:43:38 Retrying (16 of 20)...
W 21:43:38 Retrying (17 of 20)...
W 21:43:38 Retrying (18 of 20)...
W 21:43:38 Retrying (19 of 20)...
W 21:43:38 Retrying (20 of 20)...
E 21:44:00 Failed to Write Sectors 0 - 31 - Reason: Write Error
I 21:44:00 Synchronising Cache...
I 21:44:02 Closing Track...
W 21:44:02 Close Track Failed! - Reason: Write Error
E 21:44:04 Close Track Failed! - Reason: Write Error
I 21:44:04 Finalising Disc...
E 21:44:05 Failed to Write Image!
E 21:44:05 Operation Failed! - Duration: 00:00:26
I 21:44:05 Average Write Rate: N/A - Maximum Write Rate: N/A
Using DVDInfoPro, I took the screenshot of my device information
Device Hardware info
drive hardware information.png (145.29 KiB) Viewed 27576 times
DVD Media information after failed process
DVD Media Info
media information.png (131.02 KiB) Viewed 27576 times
Graph during the failed process
Graph
Also, I tried the following things.
Deleting upper & lower filter:-
PATH:- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Uninstall and Re-installing the Driver
Tried to update the Firmaware. But no new updates available
Please Help me.
Thanks,
Ramki B
ramkbala
Re: Optiarc DVD RW AD-7710H Firmware 1.V0
Postby Ian on Mon Mar 04, 2013 3:56 pm
Hi Ramki,
Have you tried other brands of media other than MBI? What happens if you turn on OPC and/or burn at say 8x?
Postby ramkbala on Mon Mar 04, 2013 11:13 pm
Ian wrote:Hi Ramki,
I used sony DVDs many times. It failed. Not to waste the DVDs, I used the local brand media. I tired burning with different speed also. Nothing worked out.
I can read DVD, but no able to write. Is there any problem with my DVD Drive. If so, any other tool is available to find it?
Thanks,
Ramki B
ramkbala
Postby Ian on Tue Mar 05, 2013 9:53 am
You could try giving the drive a few blasts with compressed air. If that still doesn't work, pull it out and try it in another computer. If it still gives an error, you'll probably need a new drive.
