Opinions on best performing QUIET drive
Postby apiro on Tue May 06, 2003 1:46 pm
Hi
Im looking for a new cd-rom and a new cd-rw. While performance is important, it is also important to me that the dive be as quiet as possible.
Im looking for you guys' opinion on the best drive combining these two features for both the reader and also the writer.
I have read some information about multi-beam technology and wanted to know your opinion of that as well.
Thanks in advance for any help.
apiro
Postby Ian on Tue May 06, 2003 1:57 pm
Don't bother with multi-beam. The technology didn't work well when it came out and I don't think the drives are even being manufactured anymore.
If you're concerned with noise, take a look at a 40x or 48x writer. I've found Samsung's drives to be pretty quiet. Otherwise look at something with a speed control feature like some of the LG and Sony drives have.
Postby vbl117 on Tue May 06, 2003 7:22 pm
Ian wrote:Don't bother with multi-beam. The technology didn't work well when it came out and I don't think the drives are even being manufactured anymore.
Yes it's a long time since Kenwood has discontinued his products .
vbl117
Postby TheWizard on Wed May 07, 2003 4:16 am
Look to LG drives for performance and quietness.
No, I like women.
Postby Halc on Wed May 07, 2003 4:18 am
There isn't much of a difference between LG, Samsung and LiteOn drives in terms of their noise at 48x.
Of course, LiteOn is by far the most noisiest, but they are all super-annoyingly-noisy.
I agree with Ian that speed control is the only thing that might alleviate the noise levels.
regards,
Halcyon
PS Yes, I've tested Samsung, LG and LiteOn at 48x myself.
Halc
Postby TheWizard on Wed May 07, 2003 6:09 am
So, get a slightly slower drive such as 32X. :) The LG GCE-8320B is very quiet.
No, I like women.
Postby jedimc on Wed May 07, 2003 6:10 am
i have the LG 8520B and itz pretty quite, but i havent had much experience with other burners. :lol:
and Samsung CD-ROM SC-148T
jedimc
Postby dolphinius_rex on Wed May 07, 2003 11:00 am
Why worry about it? I mean yes, at full speed many drives can be very noisy... but if you use Nero's Drive Speed utility you can just set your drive down a knotch or two and it'll be fine. I find my LiteON drive is fairly quiet at 32x, a little noisy at 40x and can be bothersome at 48x. Though it has been known to reach speeds of up to 56x when burning/reading a 99min CD-R, and this can be VERY noisy....
the drive is a liteON 40125S overclocked to 48125W if anyone's wondering
Postby Action Jackson on Wed May 07, 2003 11:04 pm
I find my LG combo drive to be quieter at 48x burning than my LiteON burning at 48x.
Action Jackson
Postby Scrondar on Mon May 12, 2003 3:43 pm
My LG 8520B has proven to be super quiet, and it burns everything I thow at it (including Clone CD copies).
Scrondar
Postby jedimc on Wed May 14, 2003 4:26 am
The LG drive is so good for a cheap price :) 8) :) 8) :) 8) :) 8) :)
jedimc
Postby dolphinius_rex on Wed May 14, 2003 4:47 am
jedimc: I noticed on your webpage that you are making some CD-R/W Reviews. I was just wondering how you plan to do this using an LG drive?? do you have access to a LiteON for doing testing??
Postby jedimc on Wed May 14, 2003 6:12 am
im just going to put some info about the disk eg brand,price, picture of the disks, etc.
itz gonna be really basic stuff.
anyway wat sort of tests can the liteON drives do?
They are pretty popular arent they. :D
jedimc
Postby dolphinius_rex on Wed May 14, 2003 11:48 am
why not check out my webpage for a proper answer to that question :wink:
www.digitaldolphin.netfirms.com
Postby jedimc on Thu May 15, 2003 1:51 am
I have been on your website before and i added it to favourites because it has alot of useful info :) :) :)
jedimc
