NORTH BRIDGE BURNING UP!! HELP!!
Postby oxymoron on Sat May 03, 2003 2:05 am
i need serious help
i have the msi k7n2-l, and the north bridge has reached a rec of 136 deg. F (about 58 deg C!! when i touch heat sink(passive) it like touching boiling water! also, i have a AIW 7500, which is also passively cooled, right under n/b and runs hot as well. this never happened to me before... what do yall think the problem is?
"Nothing is better than eternal happiness. Ham sandwiches are better than nothing. Therefore, ham sandwiches are better than eternal happiness."
oxymoron
Postby Inertia on Sat May 03, 2003 2:54 am
I don't know if you are overclocking, but hot Northbridge heatsinks on the MSI K7N2-L nForce2 Motherboard are not unusual.
You might consider a supplementary fan blowing air over the heatsink or a well ventilated computer case with extra fans.
In the meantime, have a ham sandwich and enter nirvana++. :lol:
Inertia
Postby kuser9 on Sat May 03, 2003 11:54 am
You can replace Northbridge cooler wiht Crystal orb cooler from Thermaltake or similar product like that.
http://www.thermaltake.com/products/chi ... talOrb.htm
kuser9
Postby aviationwiz on Sat May 03, 2003 5:06 pm
Yeah,
at the Micro Center in Minneapolis they had a display system (windowed case of course.) and they had the crystal orb cooling the north bridge. The Crystal Orb is a great idea if it will fit on your motherboard, it won't fit on all motherboards.
Postby Turkeyscore.com on Sat May 03, 2003 8:21 pm
is the heatsink clean of dust?
zzzt *pop*
Turkeyscore.com
