Hi to this forum and please help,
I'm really stuck on a very simple problem! I have read through previous posts looking for ideas but I haven't seen anything to help me. I have been working with Nero tech support but unfortunately I am getting nowhere.
I want to burn some home movies to DVD that I captured from a Canon Elura 2. I'm using the option to write to hard disk so that I can burn several DVD's with the same movie. 50 mins into the 1 hr video during transcoding I get a burn fail error. I have attached the Nero log file as well as the InfoTool file.
I have re-installed the latest Nero s/w after running the General-CleanTool, I have installed the latest drivers on my pc, and I have installed the latest drive firmware. I have disabled my antivirus s/w. No matter what I try I always get the exact same failure at the same time.
This is my first time burning movies so I just use the default settings in Nero. I also tried burning directly to disk early on with, I think, the same problem (it's been a while so I don't remember exactly) - that's another reason I tried writing to the hard disk so that I could remove the NEC writer from the problem.
I thought the error message in the log file would enable tech support to immediately identify the problem but it appears that isn't the case.
Let me know if you need more info or you want me try something.
Thanks.
I also wanted to add that I preview the captured video using the remote control feature and it plays through the part where the error occurs. So I don't think I have a corrupted video.
Logs removed by Spazmogen.
