eranros wrote:Thanks craig, that was quick!
Your Welcome!
Though I had nothing to do with it acutally. Our Engineers saw your post and took steps on their own to resolve it ASAP. Makes my job easier.
Changes from Nero 6.3.1.6 to 6.3.1.10
Features Added
Nero Burning ROM / Nero Express 6
Added support for new recorders
Bug Fixes
Fixed wrong DVD+R VR flag detection routine
Allow to select recorder in NE when loading Double Layer image
Fixed wrong DVD Video label on Asian systems
Enabled switching the fullometer when switching CD EXTRA audio and ISO part in NE
Fixed a problem accessing INTERNET CD database by increasing the timeout for users with slow INTERNET access
Fixed that Double Layer multisession disc cannot be copied
Nero Burning ROM
Added data in multisession DVD+RW was not written correctly
Added data in multisession DVD-RW was not displayed correctly
eranros wrote:Just installed and checked - bug's still there.![]()
Cheered to soon....
wicked1 wrote:I would like to see it goto NEW everytime.
eranros wrote:Version 6.3.1.17 out today - bug's still there.
Come on Ahead, it can't be that hard to fix ?!
ric wrote:[...]
(OK. then add support for longer volume labels and 256 character filenames and you'll have the perfect burner).
ric wrote:You make a good point. Now that I think about it, I don't know why I'm still using Nero6 instead of going back to 5. Except for a slightly more convenient way to select which burner you're using, I can't think of anything it adds. I'm sure there are things, but just nothing I use. I guess drive support is the issue, but I think I'll try it to see if it'll work on my drive.
