When I run Nero CDspeed, CD quaility Test, there is a check box at the bottom that says "report c1 errors". Unfortunately the box is greyed out and I cannot select it. When I run the test, the program reports on C2 errors but not on C1 errors.
I am trying to get a sense of how well my burner performs on the media I am using. When I run the test, no C2 errors are produced and Scandisk shows all sectors to be good, but I would like to see the C1 error rate to get a more accurate assement of the reliability of the media.
My computer has the system ASPI and Nero ASPI, working properly under the Nero Info Tool. I have disabled the Windows XP cd burning software. The IDE driver is running in Ultra DMA mode 2 and the drive is the only on on that cable.
I have conducted searches on this forum, as well as reading the manual and the CDspeed2000 web site. I haven't come across any answers yet.
I have Nero. 6.0 ultra edition running and have just downloaded all of the latest updates which I intend to install tonight. Maybe that will make a difference. I will advise after I have applied the updates.
My computer is a Syntax Motherboard with a built in Via Samuel Processor 800 mhz 384 MB DDR ram. Running XP Pro
Anyone have any thoughts or suggestions?
PS - Try not to laugh to hard at the motherboard and processor, it only cost $25 after rebate Unless it is causing this problem, it has worked very well so far.
