Nero CD-SPEED problems
Postby aniv3 on Mon Feb 10, 2003 3:58 pm
I have the latest nero, and when I 2 use the CD-SPEED and try 2 run some tests it just doen't work:
it loads the "spin up drive" screen (though the CD-ROM itself appears to do nothing), and I get the following error message:
"Error - PARAMETER VALUE INVALID (052602)".
furthermore, when I try 2 test a quality of some of my cd's (original and burned) it behaves very strangely:
the graph runs red like wild, the speed is bout 850x and the number of errors runs around: 500,000,000.
The CD-ROM itself isn't doing anything... in short - it's just NOT WORKING....
PLZ help me out here...
I have WinXP
Sony CDRW CRX-175A1, Toshiba DVD-ROM SD-M1612
aniv3
Postby dhc014 on Mon Feb 10, 2003 8:48 pm
It's probably a problem with the type of disk in the drive. Try doing it with an older disk that you know has no copy protection and is very clean.
dhc014
Postby aniv3 on Tue Feb 11, 2003 2:11 pm
nope, that didn't do the trick...
any other suggestions??
or maybe should I try another program??? do u know any?
aniv3
Postby AZImmortal on Mon Feb 17, 2003 4:12 am
u have these problems w/ ALL discs? or just some?
AZImmortal
Postby aniv3 on Mon Feb 17, 2003 3:18 pm
All the discs, I just can't figure it out, don't know what's causin it...
:evil:
aniv3
Postby CCampbell on Mon Feb 17, 2003 4:32 pm
Please send me information about your Recorder and system.
What model recorder ( I know you have it mentioned here)
Firmware version
Use Nero Info Tools to list all the drivers you have on your system and print this and send as well.
And as much information about your system as possible.
Forward this to me at techsupport4@nero.com and I will forward to our Q&A team to test and see if they can duplicate this issue.
If we can duplicate it, we can resolve it.
Postby aniv3 on Tue Feb 18, 2003 10:43 am
craig - just wanted 2 let u know I've sent all the info I have about my system 2 the e-mail u posted...
thx m8 :)
aniv3
Postby aniv3 on Wed Mar 05, 2003 4:51 pm
Tryinh 2 revive my post - I just can't solve this problem,
can SOMEBODY PLZ HELP ME OUT...
It's really annoying that I can't assess the quality of my burnt cd's...
aniv3
Postby dodecahedron on Thu Mar 06, 2003 4:32 am
we need more info to try and help you out.
system info and configuration:
what burner do you use, what firmware.
system: motherboard/chipset
operatin system, SPs? etc.
IDE configuration: what drives do you have and how are they set up on the IDE channels.
what IDE drivers are you using.
what burning software do you have installed.
any packet writing software?
ASPI installed? if so, which version/s, how were they installed?
did you try to update the firmware of your drive?
did you try to uninstall Nero+Nero Toolkit, clean up the registry and reinstall?
did you receive any help from Craig Campbell?
Postby aniv3 on Thu Mar 06, 2003 2:19 pm
below is the info gathered by Nero INFOTOOL, I hope it has enough info 4 u guys, and some additional info:
I also have Roxio EZCD 5 and EAC, I've tried 2 uninstall Nero but it didn't work, and I'm not exacly sure how 2 clear the registry without damaging it....
and also, craig hasn't replied, I've sent him the nero INFOTOOL txt and I've also generated a report bout my system with Sandra 2002 PRO...
I sent it again yesterday, hope he'll reply this time...
PLZ tell me how 2 continue from this point, it's just really bugs me...
NERO infoTOOL:
Drive Information
Drive : SONY CD-RW CRX175A1
Type : CD-RW Recorder
Firmware Version : 5YS2
Buffer Size : 2 MB
Date : ?
Serial Number : ?
Drive Letter : F:\
Mechanism : Tray
Read Speed : 40, 32, 24, 16, 12, 8, 4 X
Write Speed : 24, 20, 16, 12, 8 X
Read CD Text : Yes
Return C2 Pointers : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : No
Read DVD-RAM : No
Read DVD-R : No
Read DVD-RW : No
Read DVD+R : No
Read DVD+RW : No
Read Digital Audio : Yes
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : No
Write DVD-RW : No
Write DVD+R : No
Write DVD+RW : No
Write DVD-RAM : No
Buffer Underrun Protection : Yes
Mount Rainier : No
Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
Disc Information (F:\)
Type : - no disc inserted -
Drive Information
Drive : TOSHIBA DVD-ROM SD-M1612
Type : DVD-ROM Drive
Firmware Version : 1004
Buffer Size : 512 KB
Date : 01-23-02
Serial Number : ?
Drive Letter : G:\
Mechanism : Tray
Read Speed : 48, 32, 20, 8 X
Write Speed : n/a
Read CD Text : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : Yes
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD+R : No
Read DVD+RW : No
Read CD+G : Yes
Read VideoCD : Yes
Write CD-R : No
Write CD-RW : No
Write DVD-R : No
Write DVD-RW : No
Write DVD+R : No
Write DVD+RW : No
Write DVD-RAM : No
Buffer Underrun Protection : No
Mount Rainier : No
Modes : n/a
Region Protection Control : RPC II
Region : 1
Changes User : 4
Changes Vendor : 4
Disc Information (G:\)
Interface Information
Adapter 1
Description : Unknown Adapter
Driver
Description : System32\DRIVERS\siside.sys
Company : Windows (R) 2000 DDK provider
Version : 5.1.2600.0 built by: WinDDK
Description : ATAPI IDE Miniport Driver
Attached Devices
Description : ID 0 (0): IC35L080AVVA07-0 VA4O
Type : Disk Drive
Adapter 2
Driver
Attached Devices
Description : ID 0 (0): SONY CD-RW CRX175A1 5YS2
Type : CD-Rom Drive
Autorun : On
Description : ID 1 (0): TOSHIBA DVD-ROM SD-M16121004
Type : CD-Rom Drive
Autorun : On
Software Information
Operating System : Windows XP Professional (5.01.2600 Service Pack 1)
ASPI : Nero Aspi Library 2.0.1.50 Ahead Software AG
Description : Nero - Burning Rom
Version : 5, 5, 10, 0
Company : Ahead Software AG
Description : DirectCD Application
Version : 5.1.0.209
Company : Roxio
Description : UDF Reader Installer
Version : 5.0 (141)
Company : Roxio
Description : PowerDVD
Version : 4.0.1109
Company : CyberLink Corp.
Driver Information
Driver : ACPI
Description : ACPI Driver for NT
Version : 5.1.2600.1106 (xpsp1.020828-1920)
Company : Microsoft Corporation
Driver : Arp1394
Description : IP/1394 Arp Client
Driver : Aspi32
Description : ASPI for WIN32 Kernel Driver
Version : 4.71 (0002)
Company : Adaptec
Driver : atapi
Description : IDE/ATAPI Port Driver
Driver : Atmuni
Description : ATM UNI Call Manager
Version : 5.1.2600.0 (xpclient.010817-1148)
Driver : audstub
Description : AudStub Driver
Version : 5.1.2600.0 (XPClient.010817-1148)
Driver : Cdfs
Description : CD-ROM File System Driver
Driver : Cdr4_xp
Description : CDR4_XP CDR Helper
Version : 5.1.0.209
Company : Roxio
Driver : Cdralw2k
Description : CDRAL for Windows 2000 Kernel Driver
Version : 5.1.0.209
Company : Roxio
Driver : Cdrom
Description : SCSI CD-ROM Driver
Driver : cdudf_XP
Description : CD-UDF NT Filesystem Driver
Version : 5.1.0.209 built by: WinDDK
Company : Roxio
Driver : CnxEtP
Description : Conexant USB WDM
Version : 32.099.032.000
Company : Conexant
Driver : CnxEtU
Company : Conexant
Driver : CnxTgN
Description : NDIS 5.0 WAN driver for PCI ADSL adapter
Version : 13032.099.032.000
Company : Conexant Systems Inc.
Driver : ctac32k
Description : Creative AC3 SW Decoder Device Driver (WDM)
Version : 5.12.01.0245-1.31.0050
Company : Creative Technology Ltd
Driver : ctaud2k
Description : Creative WDM Audio Device Driver
Version : 5.12.01.0253-1.31.0130
Driver : ctprxy2k
Description : Creative Proxy Device Driver (WDM)
Version : 5.12.01.0244-1.31.0040
Driver : ctsfm2k
Description : SoundFont(R) Manager (WDM)
Version : 5.12.01.0140-0.75.1490 (beta-release)
Driver : Disk
Description : PnP Disk Driver
Driver : dmio
Description : NT Disk Manager I/O Driver
Version : 2600.0.503.0
Company : Microsoft Corp., Veritas Software
Driver : dmload
Description : NT Disk Manager Startup Driver
Company : Microsoft Corp., Veritas Software.
Driver : Fastfat
Description : Fast FAT File System Driver
Driver : Fdc
Description : Floppy Disk Controller Driver
Driver : Flpydisk
Description : Floppy Driver
Driver : Ftdisk
Description : FT Disk Driver
Driver : gameenum
Description : Game Port Enumerator
Driver : ha10kx2k
Description : Creative EMU10KX HAL (WDM)
Version : 5.12.01.0251-1.31.0100
Driver : hidusb
Description : USB Miniport Driver for Input Devices
Driver : i8042prt
Description : i8042 Port Driver
Driver : Imapi
Description : IMAPI Kernel Driver
Driver : IPFilter
Description : Microsoft IntelliPoint
Version : 4.00.0657.1
Driver : IPSec
Description : IPSec Driver
Driver : isapnp
Description : PNP ISA Bus Driver
Driver : kmixer
Description : Kernel Mode Audio Mixer
Driver : mmc_2K
Description : CD-R/RW AddOn MMC Driver (W2K)
Version : 5.1.0.209
Company : Roxio
Driver : mouhid
Description : HID Mouse Filter Driver
Driver : MRxDAV
Description : Windows NT WebDav Minirdr
Driver : NdisTapi
Description : NDIS 3.0 connection wrapper driver
Driver : Ndisuio
Description : NDIS User mode I/O Driver
Driver : NdisWan
Description : MS PPP Framing Driver (Strong Encryption)
Driver : NIC1394
Description : IEEE1394 Ndis Miniport and Call Manager
Driver : NPDriver
Description : Norton Protection Driver
Version : 15.03.0.36
Company : Symantec Corporation
Driver : Npfs
Description : NPFS Driver
Driver : ohci1394
Description : 1394 OpenHCI Port Driver
Driver : Parport
Description : Parallel Port Driver
Driver : PartMgr
Description : Partition Manager
Driver : ParVdm
Description : VDM Parallel Driver
Driver : PCI
Description : NT Plug and Play PCI Enumerator
Driver : PSched
Description : MS QoS Packet Scheduler
Driver : Ptilink
Description : Parallel Technologies DirectParallel IO Library
Version : 1.10 (XPClient.010817-1148)
Company : Parallel Technologies, Inc.
Driver : pwd_2K
Description : Win2000 Framework for Packet Write Driver
Version : 5.1.0.209
Company : Roxio
Driver : Rasl2tp
Description : RAS L2TP mini-port/call-manager driver
Driver : RasPppoe
Description : RAS PPPoE mini-port/call-manager driver
Driver : Raspti
Description : PTI DirectParallel(R) mini-port/call-manager driver
Driver : Rawwan
Description : Raw WAN Transport
Driver : Rdbss
Description : Redirected Drive Buffering SubSystem Driver
Driver : RDPCDD
Description : RDP Miniport
Driver : rdpdr
Description : Microsoft RDP Device redirector
Driver : redbook
Description : Redbook Audio Filter Driver
Driver : Secdrv
Description : Macrovision SECURITY Driver
Version : 3.17.000
Company : Macrovision Europe Ltd
Driver : serenum
Description : Serial Port Enumerator
Driver : Serial
Description : Serial Device Driver
Driver : sisagp
Description : SiS NT AGP Filter
Version : 6.1.2091.0 built by: WinDDK
Company : Silicon Integrated Systems Corporation
Driver : siside
Driver : sr
Description : System Restore Filesystem Filter Driver
Driver : Srv
Description : Server driver
Driver : swenum
Description : Plug and Play Software Device Enumerator
Driver : SymEvent
Description : Symantec Event Library
Version : 10.3.2.10
Driver : SYMREDRV
Description : Redirector Filter
Version : 4.5.2.01
Driver : SYMTDI
Description : Norton Internet Security Filter
Version : 4.5.2.01
Driver : sysaudio
Description : System Audio WDM Filter
Driver : Tcpip
Description : TCP/IP Protocol Driver
Driver : TermDD
Description : Terminal Server Driver
Driver : UdfReadr_xp
Description : CD-UDF NT Filesystem Reader Driver
Company : Roxio
Driver : Update
Description : Update Driver
Driver : usbhub
Description : Default Hub Driver for USB
Driver : usbohci
Description : OHCI USB Miniport Driver
Driver : usbprint
Description : USB Printer driver
Driver : VolSnap
Description : Volume Shadow Copy Driver
Driver : Wanarp
Description : MS Remote Access and Routing ARP Driver
Driver : msvcrt.dll
Version : 7.0.2600.1106 (xpsp1.020828-1920)
Driver : msvcirt.dll
Version : 7.0.2600.0 (xpclient.010817-1148)
Driver : mfc42.dll
Version : 6.00.8665.0
Driver : msvcp60.dll
Version : 6.00.8972.0
Driver : ole32.dll
Driver : olepro32.dll
Version : 5.0.5014
Driver : oledlg.dll
Version : 1.0 (XPClient.010817-1148)
Driver : advapi32.dll
Driver : comctl32.dll
Version : 5.82 (xpsp1.020828-1920)
Driver : setupapi.dll
ASPI Information
System ASPI
WNASPI32.DLL : 4.71 (0002) 45056 bytes July 17, 2002
ASPI32.SYS : 4.71 (0002) 16877 bytes July 17, 2002
WINASPI.DLL : 4.60 (1021) 5600 bytes July 17, 2002
WOWPOST.EXE : 4.60 (1021) 4672 bytes July 17, 2002
Nero ASPI
WNASPI32.DLL : 2.0.1.50 131072 bytes March 04, 2002
aniv3
Postby dodecahedron on Thu Mar 06, 2003 2:45 pm
too bad Craig Campbell has'nt helped out :o :x
it's also a pity that you didn't bother to answer the questions i asked you.
you just dumped the huge InfoTool output.
it would have been much more courteous of you to answer the questions. your'e asking other people to help you out, at least you can answer simple questions like i asked instead of dumping this huge text and expect us to dig into it and sift through to find the relevant info.
not very friendly :x
i'm not an expert on Sony/Lite-On drives, so i don't know if the 5YS2 firmware you have is the latest for your drive. maybe someone else will comment on that.
it appears that you have Adaptec ASPI 4.71. this is know to cause trouble with WinXP. there have been many such reports. it is recommended that you remove it and install ASPI 4.60.
here's a couple of links:
http://www.afterdawn.com/software/cdr_s ... rcaspi.cfm
http://www.cyrus.troy.btinternet.co.uk/downloads.htm
from which you can get ForceASPI, which can remove the current ASPI and install 4.60.
you also have Roxio's UDF Reader installed. you don't really need this to read packet-written discs by DirectCD, since you already have DirectCD installed. it is strongly recommended you uninstall it.
EDIT: not really sure about this one...so maybe you should not uninstall the UDF Reader, unless you don't actually use DirectCD (read below) in which case remove both of them.
also, if you don't use DirectCD, you might consider uninstalling that too.
after that you should clean your system of all the remaining drivers it might have left behind, i suggest you read KCK's "InCD troubleshooting guide" in the FAQ forum. although you're not interested in InCD, still that guide has info on how to spot drivers from DirectCD/UDF Reader that interfere with InCD and theoretically could cause trouble for you.
since this is rather tricky (you don't want to remove something the Easy CD Creator needs) and also involves cleaning the registry, i recomment you try my other recommendations first.
Postby aniv3 on Thu Mar 06, 2003 3:22 pm
I'm really sorry about that big list I dumped over there, I did it 4 3 main reasons: 1) some of the info u requsted is a bit over my knowledge and I didn't know exacly how 2 locate it 2) just wanted 2 cover as much as possible... 3) when I talked 2 Craig he told me 2 give him as much info as I can, so I figured I should do it here 2....
I won't do it next time... sorry 8)
and I will try ur recommendations... hope It'll fix it...
aniv3
Postby dodecahedron on Thu Mar 06, 2003 4:41 pm
it's OK
we were all newbies once...
Postby CCampbell on Thu Mar 06, 2003 6:31 pm
Hi Aniv,
Sorry for the delay in my response. I've been doing some traveling and not enough time at my desk. :(
I've checked through my Emails, and I could not find this email you had sent me. And I do clear out my emails each working day, except when I travel, then it might take two to 3 days before I get to it.
However, with the information you posted here, I did forward this issue to our Developer of the CD Speed utility and hope to get some suggestions from him ASAP, and get back to you on this issue. I attempted to duplicate your issue, but could not with your same model recorder.
Give me 3 days and I should have a response for you. :)
Best Regards,
Postby aniv3 on Fri Mar 07, 2003 6:16 am
dodecahedron -
I used forceaspi 2 completely remove the aspi layer... hen I re-installed it,
using the latest version (4 some reason the forceaspi util didn't install the 4.6 version)... and there's no change at all -
I can burn just fine but I can't use either of my drives with CDspeed....
what should I do next?
should I completely remove EZCD and nero and then re-install just nero?
aniv3
Postby dodecahedron on Fri Mar 07, 2003 8:56 am
i have'nt done it myself, but i believe ForceASPI does let you install ASPI 4.60 (that's the main purpose of ForceASPI).
i would recommend removeing ASPI and not reinstalling it.
definitely not reinstalling the latest 4.71.
neither Nero nor Easy CD Creator/DirectCD need it to work properly, and it might cause trouble, maybe the reason for your problems.
also before uninstalling Nero, i recommend giving Craig a chance, see if he has an anwer for you.
uninstalling the software and reinstalling can help, sometimes this solves problems.
again, if you don't really need/use packet writing, i suggest not installing DirectCD, just Nero.
Postby aniv3 on Sat Mar 08, 2003 9:46 am
somehtin very strange is happening:
after I've successfully removed the aspi layer with forceaspi I tried 2 install the 4.6V using forceaspi - it said that all files were successfully copied and the registrey was changed (as it should) but then after I restart the pc and use aspichk it says that I haven't installed the aspi layer
- it isn't present... I've aslo ran a search for the aspi files in the windows dir - none of them r there!!!
4 some reason forceaspi did not copy the necessary files...
any idea what might have casued this??? maybe the win dir is locked or somethin? I don't know... any suggestions?
aniv3
Postby dodecahedron on Sat Mar 08, 2003 10:17 am
like i already said, you don't really need ASPI.
make sure it is removed, and then check to see if your system is functioning properly.
Postby aniv3 on Sat Mar 08, 2003 10:28 am
got damn :evil:
I've uninstalled EZCD , uninstalled nero - removed the aspi...
then re-installed nero... and nothin changed!!! cd-speed just ain't workin!!!
I've checked sony and toshiba 2 c if they have a driver update - they dont..
I'm getting hopeless here... :cry: I also have PowerDVD and EAC, should I try 2 remove PowerDVD? (I don't want 2 start uninstalling every program I think may have somethin 2 do with it and then re-installing it)...
what do u say? what should I do next?
aniv3
Postby dodecahedron on Sat Mar 08, 2003 10:45 am
aniv3 wrote:got damn :evil:
hmm...then it would appear that the problems are'nt caused by the software or ASPI...
did you try using a registry cleaning tool?
here's a link to one:
http://www.jv16.org/
http://www.vtoy.fi/jv16/shtml/regcleaner.shtml
maybe that will help: uninstall the burning software Nero, ECDC, DCD, clean the registry and reinstall Nero.
aniv3 wrote:I'm getting hopeless here... :cry: I also have PowerDVD and EAC, should I try 2 remove PowerDVD? (I don't want 2 start uninstalling every program I think may have somethin 2 do with it and then re-installing it)...
so you use EAC...you do need ASPI then, don't you? for EAC?
i really don't know if PowerDVD would have anything to do with it.
did you hear from Craig Campbel of Ahead?
i'm afraid you may have to do a clear install of windows :o :x if we can't manage to find the problem
Postby aniv3 on Sat Mar 08, 2003 2:09 pm
shit... I've removed all of the burning softwares removed the aspi layer,
used cleanreg 2 clean whatever I can...
then re-installed only nero, and.... that DAMN CD-SPEED just won't work!!!
now I'm about 2 give up, I won't re-install windows 4 that, ain't worth the troubles... there must b a way 2 figure this out, it must b somethin simple that I'm just don't c....
yeah, I know I need an aspi layer 4 EAC, if I re-install it I'll put the aspi layer 2...
and I haven't heard from craig yet, remember it's saturday over here, I'll probaly won't hear from him till monday...
now, any other suggestions???
aniv3
Postby dodecahedron on Sat Mar 08, 2003 3:26 pm
sorry man, i done my best to try and help you, i'm at my wit's end.
short of a clean re-install of windows, i really can't think what to do.
one last possible thing to check:
decativate WinXP's built in burning capabilities.
Start button -> Run -> type: gpedit.msc -> OK
then:
User Configuration -> Administrative Templates -> Windows Components -> Windows Explorer -> Remove CD Burning features -> Enabled -> OK
Postby aniv3 on Sun Mar 09, 2003 7:59 am
nope... that didn't help, now I'm completely hopeless... :cry:
well, since I'm beginning 2 give up on that damn cd-speed...
let me ask u this:
what the hell can I do 2 check the quality of my burnt cd's?
aniv3
Postby dodecahedron on Sun Mar 09, 2003 12:56 pm
well, you have a Sony drive, this is actually a Lite-On drive, right?
so maybe (probably) it's supported by CD Doctor?
if so you can use CD Doctor to check your burns.
check out the sticky CD Doctor thread
http://www.cdrlabs.com/phpBB/viewtopic.php?t=8095
for more help on CD Doctor.
and like i said, a clean reinstall of Windows might help...
Postby cfitz on Sun Mar 09, 2003 1:05 pm
I already checked and aniv3 has an older drive that is not, I believe, a LiteOn (or Sanyo, for that matter) and probably won't work with CD Doctor. But it doesn't hurt to try.
