NERO_6 Registry_Show Record Speed_NO in P4 but YES in P2 P3
Postby daveg2541 on Wed Aug 06, 2003 8:51 am
a friend has Nero 6 on a Pentium 3 and it can
display the actual writing speed when you change
the registry setting in regedit (see below)
But ... 2 people with Nero 6 on Pentium 4's
can't it doesn't have the line in the registry anymore
"ShowSingleRecorderSpeed"
Does anyone else with a Pentium 4 have it or know
how to have Nero 6 show the writing speed like it
used to ? :-(
HKEY_CURRENT_USER\Software\ahead\Nero - Burning Rom
\Recorder
when you right click and 'modify'
from 0 to 1
Nero then displays the "actual writing speed"
when burning CDRs
daveg2541
Postby Ian on Wed Aug 06, 2003 10:14 am
Have you tried what I suggested in my email? Manually adding that reg key?
Postby aviationwiz on Wed Aug 06, 2003 11:07 am
Intresting, I have two Pentium 4's, one 2.53, one 1.6, as well as an Athlon XP 1700+, and on all three machines, right from install, it displays the actual recording speed.
Postby CDRecorder on Wed Aug 06, 2003 1:11 pm
Only older versions of Nero require you to edit the registry key to show the actual recording speed.
Postby David on Wed Aug 06, 2003 3:02 pm
I don't find this true since when I installed Nero 6 under Windows 2000 I had to edit the registry to see the actual recording speed.
David
Postby CDRecorder on Wed Aug 06, 2003 3:18 pm
Interesting... I wonder if my Nero 6 install picked up the registry key from the previous installation of Nero 5.5.
Postby David on Wed Aug 06, 2003 3:23 pm
That might be what happened since I compleatly removed Nero 5.5 and used the clean tool to clean out the registry before I installed Nero 6.
David
Postby CDRecorder on Wed Aug 06, 2003 3:26 pm
I don't remember if I removed Nero 5.5 before installing Nero 6, come to think of it, I probably didn't. :oops: In any case, I certainly didn't use any registry cleaning tools to clean Nero 5.5's entries out of the registry.
