nero problem
nero problem
Postby matrixdirect on Tue Apr 01, 2003 2:44 pm
I am tring to record a music cd. But every time I try to start a recording and add music files I get a message "out of memory" and the program freezes and need to restart the program. I have windows xp and the newst version of nero. please help
matrixdirect
Postby cfitz on Tue Apr 01, 2003 7:11 pm
Well, it probably isn't the newest version anymore, since they released 5.5.10.20 just today:
http://www.nero.com/en/index.html#download
What kind of "music files" are you adding? Are you adding .wav files, .mp3 files, or something else? Are you creating a CD-A disc? Are you using Nero Express or the traditional, full interface?
Postby matrixdirect on Tue Apr 01, 2003 7:33 pm
strange it works in full version. but when I try to do it in express it freezs
I'm backing up in wav form. and got the todays update.
matrixdirect
Postby cfitz on Tue Apr 01, 2003 7:50 pm
Does it happen with any .wav file, or just one particular one? What is the exact error message you see?
Postby CCampbell on Tue Apr 01, 2003 8:15 pm
Yes, I am also curious if this occurs with other audio files. And it's strange that you do not run into this issue in Nero Burning Rom mode.
We have seen a similar issue when you get an error message of 'Not Enough Space' when using Nero, Nero Express, or Nero Vision Express and below is the solutoin we normally use. But it should occur for all the programs.
Below is a possible solution...
Under Win2k:
Please uninstall Nero from your system using the Control Panels Add/Remove Program feature, and then delete the Ahead folder from the C:\Program Files directory.
Remove all traces of Nero (and Ahead) from Program Files and Winnt directories.
And remove traces of Nero in "Setupadi.log" and "apcompact.inf" and editted these out.
Reinstall and it should now work.
Best Regards,
Nero Problem
Postby Timmo on Thu Apr 03, 2003 1:50 am
It happend with me too some MP-3/MP-4 files Nero cant see try to change the FOrmat of that wav to mp3 or mp4 and then burn it see what happens i tried it worked that way , ENjoy..... Tim
Hello
Timmo
