Nero 6 picture VCD/SVCD problem.
Postby pranav81 on Sat Jul 08, 2006 1:45 am
Hi guys.
A friend of mine has a LG 24X burner on his old computer.He has Nero 6 on the old computer for burning purposes.
Recently he had installed Nero 7 on the computer for trial purposes.He didnt like Nero 7,so he uninstalled it and reinstalled Nero 6.6.1.4.
He can burn data CD's without any problems,but while burning VCD/SVCD from pictures,mainly .JPG's taken from a digicam,Nero crashes.When the burn button is pressed the compilation,a message saying 'Unexpected exception' is seen and the burn process fails.Nero crashes after the message.
I tried removing and reinstalling Nero 6 after cleaning the registry,but that did not help.According to my friend he was able to burn VCD fine before he installed Nero7.
I am pasting the fresh log so,you can see the problem.
Log:-
Code: Select all
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=6656 bytes, created 11/4/2004 12:03:08 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
(Nero Express)
Recorder:             <HL-DT-ST CD-RW GCE-8240B>Version: 1.08 - HA 1 TA 1 - 6.6.1.4
Adapter driver:      <IDE>                     HA 1
Drive buffer  :      8192kB
Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <SAMSUNG  CD-ROM SC-152C  >Version: CS05 - HA 1 TA 0 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral       : SAMSUNG SV4002H                  atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : SAMSUNG CD-ROM SC-152C           atapi Port 0 ID 1  DMA: On
CdRomPeripheral      : HL-DT-ST CD-RW GCE-8240B         atapi Port 1 ID 0  DMA: On
DiskPeripheral       : SAMSUNG VG32163A    (2.16GB)     atapi Port 1 ID 1  DMA: On
=== CDRom-Device-Map ===
SAMSUNG CD-ROM SC-152C     F:   CDRom0
HL-DT-ST CD-RW GCE-8240B   G:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 247MB (253424kB)
Free physical memory: 98MB (100456kB)
Memory in use       : 60
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
8.7.2006
Video CD
1:28:56 AM   #1 Text 0 File VCDDoc.cpp, Line 1384
   VideoCD document burn settings
   Compilation type           : VCD
   Menu                       : Disable
   Picture in separate folder : TRUE
   Folder name                :PICTURES
   Use CD-I                   : TRUE
   CD-I configuration         : CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
   Encoding bitrate mode      : User defined (kb/s)
1:29:04 AM   #2 Text 0 File Isodoc.cpp, Line 6475
   Iso document burn settings
   Simulate                : FALSE
   Write                   : TRUE
   Finalize CD             : TRUE
   Multisession            : FALSE
   Burning mode            : DAO
   Mode                    : 2 / XA
   ISO Level               : 1 (Max. of 11 = 8 + 3 char)
   Character set           : ISO 9660
   Joliet                  : TRUE
   Allow more than 255 characters in path  : TRUE
   Write ISO9660 ;1 file extensions        : TRUE
1:29:05 AM   #3 Text 0 File Burncd.cpp, Line 5705
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 5/6/2002 11:01:14 AM
Registry Keys:
====== *** Nero-Burning Rom, History File *** ======
pranav81
