1. I purchased and downloaded Nero 7. The web page says InCD 5 is included. It isn't!!!! A letter from tech support says it is not included in the "standard" download (whatever that is) and proceeds to tell me how to get it from the Smart Start menu:
“The standard installation of Nero 7 does not automatically install InCD.
Follow the step below to install InCD:
In Nero StartSmart select
>Nero Tool Kit
>Nero ProductSetup
>Modify your Nero Products
Go through the "Nero Installation Wizard", the application InCD can now be installed by a right-click on the InCD option.”
But these instructions take you to a place where InCD isn't mentioned. There is no place on their web site to download it.
2. When I downloaded the (then) latest version of Nero 7 (Nero-7.0.1.4b_eng.exe) it wouldn't install. A message said that it was already running and must be shut down. Nothing was running! I shut down everything except Explorer and Systray, as well as stopping the virus scan and firewall. I finally used the clean tool prior to installation and it installed ok (I think?!).
3. The backup tool would not make a boot floppy in the A: drive. It returned the message "Copy image process has failed".
4. I downloaded the latest version--Nero-7.0.1.4b_eng_no_yt.exe--and nothing has changed.
Can anyone offer any help?
Stu Culp
