NERO Burning Rom 8 Problems
Postby thailand on Sat Dec 22, 2007 8:28 am
Hello,
I use the latest version of Nero 8 and have a lot of problems with burnig audio CD's.
1. The order of the tracks is not the same as with the original tracklist.Its not alfabetically sorted.. is just random i think.
2. When I burn audio cd's 95 % of them are not good playable. When i want to verify the cd its keep goin on for ever and the cd is ready for the trashcan
I have an Plextor PX760 A Burner and NEC ND3500A.
I normally use TDK , Verbatim, Platinum media to burn and i burn on 24 x speed...
The both work fine with other burning software .
Can someone help please
thailand
Postby Ian on Sat Dec 22, 2007 9:29 am
I've run into the same problem with the track ordering with Nero 7. I haven't found a good solution beyond going in and manually fixing it.
As far as the discs not playing, have you tried testing the writing quality with the 760A?
Postby thailand on Sat Dec 22, 2007 12:27 pm
Yes i did...
Strangly i did remove Nero and burned 8 cd's with ashampoo...all 8 ok
I then reinstalled nero...burned 3 cd's and all 3 are BAD ??
I then used the plextools program and all cd's Ok
I deleted nero again ..
Then installed version 7.10.1.0 of Nero 7
I burned 4 cd's and all are ok ??????
Whats wrong in nero 8 for me
Is it because it uses SideBySide...
I get also PlugAndPLay error in my logfile when i use nero 8
With other version i get no errrors ..
PLEASE HELP ???????????
thailand
