Need help with updating firmware 1.03 to lg gce-8400b
Postby gzeltser on Sun Dec 15, 2002 8:10 am
i am trying to update the drive to firmware 1.03 but when i type:
a>je4 je4lg724
nothing happens.
i am using windows xp pro.
thanks
gil.
gzeltser
Postby dodecahedron on Sun Dec 15, 2002 3:39 pm
are you typing this in a command window?
i think the updater has to be run in real DOS, not from a command prompt from within Windows.
Re: Need help with updating firmware 1.03 to lg gce-8400b
Postby vio_man on Sun Dec 15, 2002 6:07 pm
gzeltser wrote:i am trying to update the drive to firmware 1.03 but when i type:
a>je4 je4lg724
nothing happens.
thanks
gil.
The correct syntax is: je4 je4lg724.hex :lol:
vio_man
Postby gzeltser on Tue Dec 17, 2002 6:29 am
i am doing it in real dos with win95 boot diskate
and as for the command in lg site they say to write it without the extention.
gzeltser
Postby dodecahedron on Tue Dec 17, 2002 10:24 am
well, try it with the .HEX anyway, what can it hurt?
when i tried to update the firmeware of my LG CD-ROM drive, the instructions said to write the .HEX and it didn't work. tried without the .HEX and it did!
look here: http://www.cdrlabs.com/phpBB/viewtopic.php?t=4055
