need help selecting a dvd writer
Postby greenbean on Tue Aug 15, 2006 11:48 am
I don't know much about dvd writers and I'm looking to buy my first one. I primarily want to use it to back up software and create picture cd's, things like that. I don't want to spend much and I see a lot of burners around $30 on newegg but I'm not sure if any of those will do. Also could use help selecting the proper media for whichever drive I buy. Also do burner work with copy protection?
Thanks.
greenbean
Postby greenbean on Tue Aug 15, 2006 11:52 am
http://www.newegg.com/Product/Product.asp?item=N82E16827106014
Is that drive any good? Low price and free shipping, I have a lite-on cd writer and it sounds like a chainsaw sometimes. Is that common with lite-on?
greenbean
Postby TCAS on Tue Aug 15, 2006 12:10 pm
Lite-On did score pretty high in producing CD writers but when came to DVD users and customers were not that happy with Lite-On brands. But still for $28 I would not worry about it after all the $28 only get you a good humberger lunch.
Postby hoxlund on Tue Aug 15, 2006 12:39 pm
i would stay away from lite-on dvd writers, common understanding i think round these parts
here are some better ones:
http://www.newegg.com/Product/Product.a ... 6827101010
http://www.newegg.com/Product/Product.a ... 6827136091
http://www.newegg.com/Product/Product.a ... 6827249003
Postby Ian on Tue Aug 15, 2006 1:46 pm
Check the montly DVD writer polls. This should give you an idea of which drives the people on this forum think are the best.
http://www.cdrlabs.com/phpBB/viewtopic.php?t=22057
http://www.cdrlabs.com/phpBB/viewtopic.php?t=21922
Postby hoxlund on Tue Aug 15, 2006 1:54 pm
of course that works tons better then my idea, thx ian
Postby greenbean on Tue Aug 15, 2006 2:37 pm
thanks I appreciate it!
greenbean
Postby greenbean on Tue Aug 15, 2006 2:42 pm
Think I'll go for the BenQ. Any suggested media?
greenbean
Postby [buck] on Tue Aug 15, 2006 2:55 pm
Another option is the Pioneer DVR-111 for $32 shipped at Newegg. It also comes with a 50pk of Verbatim inkjet printable 16X DVD-Rs :o (you need to select the Pioneer/Verbatim combo at the checkout screen)
edit: nevermind, it appears the DVD-Rs are now out of stock.
Personally, I'd probably for the BenQ as my primary drive, but the 50pk of Verbatim DVD-Rs makes it an incredible deal.
Postby greenbean on Tue Aug 15, 2006 3:13 pm
hmm yea that is a good deal. so that drive is not as good as the benQ though?
greenbean
Postby hoxlund on Tue Aug 15, 2006 3:26 pm
im partial to pioneer, ive had mine since they first came out
still a solid performer, but i never use it for burning anymore
it is only used for dvd-rom use during the copying process
Postby greenbean on Tue Aug 15, 2006 3:28 pm
well that free 50 pack is out of stock it seems.
greenbean
Postby greenbean on Tue Aug 15, 2006 3:44 pm
do i need dvd-r or dvd+r for the benQ?
greenbean
Postby [buck] on Tue Aug 15, 2006 3:45 pm
greenbean wrote:do i need dvd-r or dvd+r for the benQ?
Either, doesn't matter. I'd recommend Verbatim DVD+Rs.
Postby greenbean on Tue Aug 15, 2006 3:54 pm
ok, I wasn't sure if it was picky. :)
greenbean
