msi 8348s 48x-24x-48x problem
Postby se7ss on Mon Mar 10, 2003 10:02 am
i bought the writer two days ago and i can only write with 24x speed i know i have the burn proof thing but how can i remove it with nero....
or ther is anything else to do plz advice
thanks
se7ss
Postby Bhairav on Mon Mar 10, 2003 10:05 am
Please try not posting the same topic twice!
Postby se7ss on Mon Mar 10, 2003 10:07 am
its was by mistake sorry
se7ss
Postby Ian on Mon Mar 10, 2003 11:38 am
It's actually the drive's EXACT-Rec technology limiting your writing speed. The only thing you can do is try other media.
Postby cfitz on Mon Mar 10, 2003 11:49 am
Postby se7ss on Mon Mar 10, 2003 4:11 pm
sorry to say i'm a newb ..and i am not really sure..and i have a windows 98 SE operating system not xp plz advice..
se7ss
Postby cfitz on Mon Mar 10, 2003 4:13 pm
Here is the guide for 98:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9683
You might want to check the FAQ section as a whole:
http://www.cdrlabs.com/phpBB/viewforum.php?f=17
Postby se7ss on Mon Mar 10, 2003 4:17 pm
.sorry about the thing just before,,.. yes i checked the dma and its enabled... :-?
se7ss
Postby cfitz on Mon Mar 10, 2003 4:23 pm
Then it is probably the media limiting your burn speed as Ian suggested. What discs are you using, brand and speed?
Postby se7ss on Mon Mar 10, 2003 4:25 pm
MINA LIFE cdr-r80 80min/700mb 48x
se7ss
Postby cfitz on Mon Mar 10, 2003 4:28 pm
Never heard of them. Do you have a link to them? Where are you from, and what other brands are available to you?
Postby se7ss on Mon Mar 10, 2003 4:34 pm
i am from jordan..no sorry there is no link to them..its made in taiwan..
but i use them because they are kind of cheap you know :)
but they used to work just fine on the LG 40x-12x-40x gce-8400b
i have these types availabe
optispeed
data life
imation
and some other kinds but cant really remember..
se7ss
Postby cfitz on Mon Mar 10, 2003 4:46 pm
Try the Verbatim DataLife and the Imation, and see if they do any better for you.
Postby cfitz on Mon Mar 10, 2003 4:48 pm
By the way, are you aware of and using CD Speed (www.cdspeed2000.com) for help with testing?
Postby se7ss on Mon Mar 10, 2003 4:51 pm
i will check them out and see what happens,,,
i just wanna ask if the under run buffer protection has something to do with problem..
and thank you so much for ur help
se7ss
Postby Ian on Mon Mar 10, 2003 5:23 pm
se7ss wrote:i will check them out and see what happens,,,
No, as I said before, its EXACT-Rec doing it.. not BURN-Proof.
Postby cfitz on Mon Mar 10, 2003 5:26 pm
No, it isn't the buffer underrun protection that is causing this, and you definitely do not want to disable buffer underrun protection. As Ian noted, it is EXACT-Rec that adjusts/limits writing speed in order to make better quality burns. You can trust Ian. He knows his stuff. After all, he founded this site and writes most all of the reviews here. :D
Postby dodecahedron on Mon Mar 10, 2003 7:21 pm
se7ss wrote:i am from jordan..
hehe!!! :D
we are neighbours! :P :P :P
Postby cfitz on Mon Mar 10, 2003 10:26 pm
There have been a surprising number of posts from your neighborhood lately. It's good to see.
Postby Harrier on Tue Mar 11, 2003 11:03 am
Careful.
The Imation CDrs in Jordan are probably made by CMC.
Harrier
Postby cfitz on Tue Mar 11, 2003 12:28 pm
My experience is that most, if not all, Imation discs are made by CMC these days (of course that could vary in other parts of the world). But Imation's CMC discs seem to be one of the better grades of CMC. So, lacking anything better to try, they are worth a shot.
