Model 4816A in Cendyne 48 x 12 x 48 Box what is it?
Postby Entropy on Sat Apr 26, 2003 8:51 am
Did some sleuthing on the net and came up with two possibilities. First, is that is the model number of an Asus drive 4816a which is actually rated at 48 x 16 x 48. Second, is that it is a Benq drive and the model number is a variation on their 4816P. The A replaces the P indicating it was manufactured in Australia. Both explanations are plausible.
If it is an Asus drive I will be keeping it and if it is a Benq it goes back. I would rather not go through the trouble of opening and installing it. Hoping somene has done that already and can enlighten me. So is it a Benq or an Asus? Thanks.
Entropy
Postby hoxlund on Sat Apr 26, 2003 11:28 am
if you buy a cendyne and the model number on the back of the box starts with LTR then its a lite-on drive inside
I know it's not a Liteon...
Postby Entropy on Sat Apr 26, 2003 12:07 pm
hoxlund wrote:if you buy a cendyne and the model number on the back of the box starts with LTR then its a lite-on drive inside
Just trying to determine if it is a Benq or Asus....
Entropy
Postby hoxlund on Sat Apr 26, 2003 12:13 pm
the asus models here in CO have the model number 5224 something like that, just numbers corresponding to the cd drive speeds
Postby alchip80 on Sat Apr 26, 2003 1:11 pm
Entropy
I had a friend purchase several of the Cendyne drive the 48x and 52x series. What he discovered was that when it says. 4816a or 5224a on the box it as a ASUS model. When he picked one up that said 4816p it was a Benq model.
Also he discovered that the 5224 w/o (a) was a Aopen drive. So it so far appears to be the (a)= Asus, p=Benq and no small letter = Aopen.
Also the LTR as previously mentioned is Liteon.
Hope this helps.
alchip80
Thanks everyone....!
Postby Entropy on Sat Apr 26, 2003 3:27 pm
Entropy
Postby hoxlund on Sat Apr 26, 2003 11:37 pm
thx for clearing that up, all i cared to know was that the litey's were LTR's on the model number
Postby tweakmeup on Mon Apr 28, 2003 4:02 am
I too have this drive, have you had any luck with upgrading the firmware?
I tried the Asus one but it did not work
tweakmeup
Postby CDRecorder on Mon Apr 28, 2003 7:00 am
Welcome to CDRLabs, Tweakmeup!
What firmware revision do you have installed on your drive?
Postby tweakmeup on Mon Apr 28, 2003 6:21 pm
the current firmware on the drive is 9E.K
tweakmeup
Postby Ian on Mon Apr 28, 2003 6:56 pm
tweakmeup wrote:Thanks :)
You have a BenQ drive.. not an ASUS.
Postby k000 on Thu May 01, 2003 12:42 am
Even I got this 9E.K firmware.. although the box was saying 4824P, it came out as 48x16x48.
So, if it is a BenQ, then it is definitely going back !
k000
