Micro Advantage 16x Dual Format DVD+/-R/RW Drive
Postby redlider on Tue Dec 14, 2004 12:13 pm
Hello I post this, Topic, for all the people that whant to help, aporting Information about this DVD Burner, so if any whant to contribute good Info or Bad recomendation please put it here.
post any coment, problems, solutions, compatibility and more about this Burner TNX.
ALWAYS SUPORT
redlider
Info about this Device
Postby redlider on Tue Dec 14, 2004 12:31 pm
16x DVD writer supports both + and - standard format
Backup your data, share films, record music
Store up to 8.5 GBs of content with Dual Layer technology on one DVD disk
Compatible with virtually all DVD video players and DVD-ROM drives
2MB data buffer
Includes Nero 6 CD/DVD Recording Suite software
Rewrite speed: 4X (DVD) or 32X (CD)
Write speed: 16X (DVD) 8x(DVD+R Dual Format Mode) or 48X (CD)
Read speed: 16x (DVD) 8x DVD Dual Format Mode) or 48X (CD)
ALWAYS SUPORT
redlider
Postby redlider on Tue Dec 14, 2004 12:47 pm
here u can download the 16DDVDRW-A13 – DVD±RW 16X
Firmware - Version 60 update to Nov '04
http://www.microadvantage.net/downloads/A060G.exe
DVD Media Support List Nov '04
http://www.microadvantage.net/downloads ... iaList.pdf
CD Media Support List Nov '04
ALWAYS SUPORT
redlider
Postby dhc014 on Fri Dec 17, 2004 4:44 am
Looks like it's the same as an AOpen DUW1608.
dhc014
Postby redlider on Tue Jan 04, 2005 11:40 am
DOES ANY HAVE ANY PROBLEM BURNING DVD WHIT THIS DEVICE ?
ALWAYS SUPORT
redlider
Postby Scour on Tue Jan 04, 2005 5:26 pm
redlider wrote:DOES ANY HAVE ANY PROBLEM BURNING DVD WHIT THIS DEVICE ?
Psst, be a little quiet ;)
Ian will review this device and he wrote that he have problems with writing DVD+RW
Postby Ian on Tue Jan 04, 2005 5:50 pm
Scour wrote:Ian will review this device and he wrote that he have problems with writing DVD+RW
The problem was actually the hard drive. I later found out that it was failing. Which reminds me.. I still need to RMA it. #-o
The review should be done soon. Let's just say NEC and Pioneer have nothing to worry about.
Microadvantage Superdrive
Postby JMarlon1 on Tue Feb 01, 2005 2:16 pm
I recieved this drive as a Christmas present. I currently use a Power MAC G4 500mhz. I use this drive in a firewire case and connected with a firewire port on my machine. Here is the issue I am having. I can burn DVDs, but they will not read in my Mac's DVD ROM. I also cannot RIP using Mac the Ripper from this Drive. I keep getting a IR read error. I can not take the drive back since it is after 30 days. I am waiting patiently so to speak to hear from MicroAdvantage support. my guess is they are going to reply that the drive is not compatible with MAC.
Does anyone have any ideas?
JMarlon1
Re: Microadvantage Superdrive
Postby Wesociety on Tue Feb 01, 2005 11:20 pm
JMarlon1 wrote:Does anyone have any ideas?
First thing they will tell you to do is update your firmware.
http://www.microadvantage.net/downloads/A070G.exe
Postby JMarlon1 on Wed Feb 09, 2005 9:47 am
I updated the firmware and still not resolved. I did recieve an email from Microadvantage, but they said the same thing. and of course they do not support MAC.
JMarlon1
