Memorex 54/24/52 firmware
Postby dbreaux on Sat Sep 06, 2003 8:16 pm
How do I get my burner to accept a LiteOn firmware upgrade in Win XP?
dbreaux
Postby CDRecorder on Sat Sep 06, 2003 9:47 pm
Use FlashFix to flash the Lite-On firmware upgrade onto your Memorex drive.
Postby Bhairav on Sat Sep 06, 2003 10:47 pm
Erm, if I'm not mistaken, 54/24/52 - Isn't that a Mitsumi drive?
Working fine
Postby dbreaux on Sat Sep 06, 2003 10:55 pm
Many months ago I was told at this forum that the Memorex 52/24/52 was a LiteOn rebadge...apparently so because the flashfix worked fine......well, there was an initial CTD at the initial reboot but all seems fine now. Files drag and drop with Roxio DragtoDisc and the burner even shows up as a LiteOn in Device Manager. Thanks for the help!!!
dbreaux
Postby CDRecorder on Sat Sep 06, 2003 11:31 pm
Well, if the flash succeeded and the drive appears as a Lite-On, the drive certainly is a Lite-On. I'm glad that FlashFix worked for you! :D
BTW, what is a CTD?
CTD
Postby dbreaux on Sun Sep 07, 2003 12:24 am
Crash to desktop.....which is not quite accurate for Win XP.....just got one of those blue screens with the typical scribbly scrabbly error message jargon. CTD is common verbage for Win 9x and earlier versions. Thanks again for the fix!
dbreaux
Postby CDRecorder on Sun Sep 07, 2003 12:32 am
You're welcome. :D
That's strange that Windows crashed the first time; I'm glad that this didn't continue happening, though! :)
