memorex 52x burner and xp
Postby mrpoi on Tue Jan 28, 2003 12:03 pm
I'm new here...hoping you can help....
Have a 52x burner from memorex....and winxp pro with sp 1.
Can use no burning software other than nero and roxio...because xp won't see my cdrw as a ...cdrw.....installed aspi already....any help please?
icq is 207816292
Thank you very much in advance
mrpoi
Postby Ian on Tue Jan 28, 2003 12:43 pm
Does the software you're trying to use even support that drive?
How about giving us some more info.. like the names of the software that doesn't work and their versions.
Postby mrpoi on Tue Jan 28, 2003 12:47 pm
That's simple....NOTHING works save Nero and Roxio
that is...disk juggler.....clone cd...cdrwin...etc....
they do NOT work
no firmware available from memorex either
mrpoi
Postby Reg-da-Ripper on Tue Jan 28, 2003 3:52 pm
Make sure that your IDE cable is secured onto your burner and your motherboard.
If you are using "cable select" on your burner, here's one word of friendly advice: don't. Select either "master" or "slave" for your burner (depending on your computer's configuration).
My solution to the Plextor vs. Lite-On debate: Buy 'em both! :)
Reg-da-Ripper
