my LTR-52246S is trippin help!
Postby g0ofy on Tue Dec 12, 2006 5:59 pm
ok it says i have no disc in the drive when i put one it. it only reads music cd's, im not sure if it used to read dvds but it doesnt. it doesnt even read my utilities cd that came with my computer. and i cant even burn music, cus it says its only a cd rom drive. any help is greatful. thanks
g0ofy
Postby g0ofy on Tue Dec 12, 2006 6:01 pm
oh and i upgrade that thing to 6SOF too. still same problem
g0ofy
Postby Spazmogen on Sun Dec 17, 2006 7:57 am
Did it work fine in the years prior to 2006?
Which operating system? Do you have an ASPI intalled?
Which cd burning program do you use?
DVD...it never did handle them. Its only a cd burner.
I owned one of those drives, and it was rock solid for the time I had it.
Postby SkaarjMaster on Mon Dec 18, 2006 4:48 pm
Got one in my Win98SE computer that still works..............well, the last time I used it that is.
OK, so I didn't really help you out much. Did you get it to work correctly yet or is it toast?
SkaarjMaster
Postby Scour on Fri Dec 22, 2006 8:19 pm
Maybe a drive-issue? Did u install a new driver or burning-program last days?
Postby ruderacer on Sat Dec 30, 2006 1:06 am
Have one and still use it every day. I love it.
Try Spaz's suggestion it might help.
"It's the voyage that counts, not the totality of life".
Every Saint has a Past! Every Sinner has a Future!
ruderacer
Postby SkaarjMaster on Sat Jan 27, 2007 8:18 pm
I've decided to use my 52246S to burn CD-Rs for a while and use my BenQ 1655 for DVDs only for a while and see how it goes! :D
EDIT: I probably said this in another thread somewhere in this forum, but I'm using the BenQ 1655 for burning both DVDs and CD-Rs because the scans are almost exactly the same for CD-Rs (TY media, the good ones before the quality started going downhill slightly). It's also a lot easier than firing up the older computer.:)
SkaarjMaster
