code65536 wrote:That slowing down a burn will always improve quality is a myth. The answer is maybe. Often, burning at a slower speed can help. But sometimes, burning at a slower speed will actually produce worse results. This is because the quality of a burn depends on other factors in addition to the burn speed. The quality of a slower burn would depend on whether or not the disc was designed for lower speeds (16x media, for example, use chemicals optimized for high-speed burning) and whether or not the drive was designed to burn that particular media at lower speeds (i.e., whether or not the drive's hardware is optimized for lower speeds, whether or not the drive's firmware is optimized for lower speeds, and whether or not the drive has a good, optimized low-speed write strategy for that particular media type). All this varies between drive types and different media, so the only way to know for sure would be to try it out.
If you are considering the use of a hacked firmware to force slower burns: If a drive's firmware does not officially support a lower speed for a particular media type, forcing the drive to burn at an otherwise unsupported lower speed through the use of a hacked firmware will likely produce undesirable results.
All Content is Copyright (c) 2001-2024 CDRLabs Inc. |
