Liteon 52246 Not Reporting C1 Errors with CDSpeed v2.02
Postby partialresponse on Tue Aug 26, 2003 12:14 am
Can someone explain why this is the case? I have firmware V6SOC. There's a little check box on the 'CD Quality Check' window that's greyed out.
Thx
Kofi
partialresponse
Postby David on Tue Aug 26, 2003 12:17 am
It's grayed out since the c1 reporting isn't in the current version of cd-dvd speed. Heres hoping the next version it will be functional.
David
Postby Inertia on Tue Aug 26, 2003 12:28 am
I don't know the answer, but this is my take on the subject:
I believe that Erik Deppe (the author of CD Speed) is working on C1 error reporting, but it isn't implemented yet.
Each drive manufacturer may use a different code or procedure for accessing C1 errors, so this probably is a difficult project.
Inertia
Postby dolphinius_rex on Tue Aug 26, 2003 3:35 am
Inertia wrote:I don't know the answer, but this is my take on the subject:
I can confirm this :wink:
Actually it *WAS* supposed to be out already, but I think he had more problems then was initially anticipated. We *SHOULD* see C1 error reporting in the next version, although the next version might still be a ways away :cry:
still, it's worth waiting for! :D
