Lite On SHW 160P6S and Memorex 8X DL won't burn
Postby Jackpine on Thu Jan 03, 2008 11:55 pm
I have no problem burning Memorex 2.4X DL discs with my Lite On SHW 160P6S burner and Nero Burning ROM 7. The firmware I am using is the PS0B version.
However, when I tried to burn Memorex 8X DL discs with the same burner and firmware version, they won't burn. So, I installed the latest firmware version from Lite On (PS0C) and tried again. This produced the same result; I can't burn Memorex 8X DL discs. I then tried to burn a 2.4X DL disc with the PS0C firmware and it worked fine.
Can anyone tell me what the problem is? The burn log showing failure to burn Memorex 8X DL discs is shown below.
(I also notice that when using the PS0C firmware, the log of activities on Nero Burning ROM includes the two following statements, just before the failure message is received:
Generating DVD high compatibility borders
Generating DVD borders completed successfully.
When I burn using the older PS0B firmware, these messages don't appear. I have no clue why this is so. Is this related to the problem?
Thanks for any help.
Burn Log:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder: <LITE-ON DVDRW SHW-160P6S>Version: PS0C - HA 1 TA 1 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
CD-ROM: <LITE-ON COMBO SOHC-5236V>Version: R$0G - HA 1 TA 0 - 7.8.5.0
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON COMBO SOHC-5236V atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHW-160P6S atapi Port 0 ID 1 DMA: On
DiskPeripheral : WDC WD2500KS-00MJB0 iaStor Port 2 ID 0 DMA: On
DiskPeripheral : datadrive iaStor Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON COMBO SOHC-5236V D: CDRom0
LITE-ON DVDRW SHW-160P6S E: CDRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 2047MB (2096148kB)
Free physical memory: 1494MB (1530572kB)
Memory in use : 26 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
3.1.2008
UDF/ISO compilation
10:01:36 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:01:37 PM #2 Phase 112 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation started
10:01:37 PM #3 Phase 114 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation completed (no file modified)
10:01:37 PM #4 Text 0 File Isodoc.cpp, Line 6608
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
10:01:37 PM #5 Phase 111 File dlgbrnst.cpp, Line 1762
DVD-Video files sorted
10:01:37 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
10:01:37 PM #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
10:01:37 PM #8 Text 0 File Burncd.cpp, Line 3499
10:01:38 PM #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3713119 (825:08.19, 7252MB)
10:01:38 PM #10 Text 0 File DlgWaitCD.cpp, Line 319
10:01:38 PM #11 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: LITE-ON DVDRW SHW-160P6S, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: S04, Product revision number: 66
Disc Application Code: 0, Extended Information Indicators: 3
10:01:38 PM #12 Text 0 File DlgWaitCD.cpp, Line 493
10:01:38 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
0: TRM_DATA_MODE1 ()
original disc pos #0 + 3713120 (3713120) = #3713120/825:8.20
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3713120 blocks [E: LITE-ON DVDRW SHW-160P6S]
10:01:38 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7604469760, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3713120 | 0 | 0x00
3713120 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:01:38 PM #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:01:38 PM #16 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
10:01:38 PM #17 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
10:01:38 PM #18 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
10:01:38 PM #19 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
10:01:38 PM #20 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11,080 KB/s)
10:01:38 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
10:01:38 PM #22 Text 0 File DVDPlusDualLayer.cpp, Line 490
L0 Data Zone Capacity already set to 2086912 (1FD800h, 4076MB), requested last LBA L0 1856671 (1C549Fh, 3626MB) ignored
10:01:38 PM #23 Text 0 File DVDPlusDualLayer.cpp, Line 653
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
10:01:38 PM #24 CDR -1205 File DVDPlusDualLayer.cpp, Line 669
Burning Layer 1
10:01:38 PM #25 Text 0 File DVDPlusDualLayer.cpp, Line 679
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
10:01:38 PM #26 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
End Sector Number in Layer 0: 22D7FF h (LBN: 1FD7FF h, 4075 MB)
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: RITEK...
Media type ID: S04
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..63]:
00 00 03 52 49 54 45 4B - 00 00 00 53 30 34 42 40 ...RITEK...S04B@
25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
10:01:38 PM #27 Text 0 File DVDR.cpp, Line 6977
Drive: LITE-ON DVDRW SHW-160P6S
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0
10:01:38 PM #28 CDR -1207 File DVDR.cpp, Line 6356
Book Type automatically set to: DVD-ROM
10:01:38 PM #29 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
10:01:38 PM #30 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
10:01:39 PM #31 SPTI -1046 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Code: 0x30
Sense Qual: 0x06
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06
Buffer x09010040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:01:39 PM #32 CDR -1046 File Writer.cpp, Line 303
Illegal disc
10:01:39 PM #33 Phase 127 File dlgbrnst.cpp, Line 1762
10:01:40 PM #34 Text 0 File DVDPlusRW.cpp, Line 934
EndDAO: Last written address 0
10:01:40 PM #35 Phase 129 File dlgbrnst.cpp, Line 1762
10:01:40 PM #36 Text 0 File DVDR.cpp, Line 6977
Book Type request [LO], rev 3: DVD+R DL
10:01:40 PM #37 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11,080 KB/s)
10:01:40 PM #38 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:01:42 PM #39 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
10:01:42 PM #40 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
Jackpine
Postby Ian on Fri Jan 04, 2008 12:24 am
The "Illegal disc" error usually indicates that the media is not supported by the drive.
