Lite-On LTR-52246S Help.
Postby jackjohnson24 on Tue Dec 10, 2002 10:42 pm
I have the Lite-On LTR-52246S , and when i first got it, it was fine. It burnt at the right speed. But all of a sudden, it takes like twice aslong to burn a cd. Using nero speed, it took like 2:30 to burn a cd. Even on a simulation w/ nero it was about the same time. But now, it takes 5 min to burn a full cd, and in nero cd speed, the speed peaks at 26x, then takes a big drop to 13x every single time. I checked it device manager and it says the drive is in pio mode. Is that the problem. I tried switching to dma but nothing works, it stays at pio. I tried uninstalling the ide controller, everything. I dont know, can someone help. This sucks.
jackjohnson24
Postby Dartman on Wed Dec 11, 2002 12:53 am
You might want to make sure it's recognised properly in the bios of your machine as UDMA.
I had that happen a couple of times and I had to go to the device manager/IDE controller/ advanced settings and reset it to udma.
This was in XP. My bios recognizes the drive proerly so that part was never a problem here.
