1st thing: is it worth overclocking 333 ddr memory to 400 ddr? the timings of the cas increase from 2.5 to 3.0 as soon as i pass 170.
2nd thing: do the other numbers mean (ras, cas, ect)? i know cas lagency is improtant....
3rd thing: do u know if my basic muskin pc2700 will operate w/ cas lagency @ 2 instead of 2.5?
the other 5 questions are off topic:
1) are there any good modems out there? is the price of a 'good modem' justified? i going to try to talk to my dad about getting cable, but i was wondering just incase he says no.
2) the s-bracket. i have a msi k7n2-L and i was wondering if (and where) i can buy the s-bracket. i have the pins for it, so i think i can use it...
3) if i cant get the s-bracket, then i will probably get a sound card. i was looking at the turtle beach santa cruse b/c its cheapcheapcheap. is that any good? i am asking these questions b/c want surround sound and line in. (getting ati aiw 8500dv)
4) any recomendations for a fanbus controler? my sys sounds LIKE A VACUUM CLEANER.
5)how do u convert a hard drive form fat32 to ntfs? if i did, will it increase hdd space (its a 60 gig hd, it says 55 gb).
thats all of my questions (i think
![8)](http://cdrlabs.com/forums/images/smilies/icon_cool.gif)
my sys.
-AMD Athlon XP 1800+ @ 1800~1940 (it varys b/c i using stock cooling and temp can get to 61~62C) via 154~170 fsb
MSI K7N2-L
WD 60gig hd
maxtor 8 gig hd
48/16/48 optorite
4/4/24 pacific digital corp.
future case (i dont konw who they are either
CRAP sis 305 graphic card
CRAP modem
some fans that came w/ case and old tt vol. 5 fan
thx for ur imput....
and i know i asked 1 2 many questions, but i didnt want to put 1200 posts out there...
