InCD does not recognize my external Firewire Burner.
Postby MadDog5145 on Sat Mar 01, 2003 3:41 pm
I have an internal burner inside an external enclosure so I can hook it up to my laptop. It has both Firewire and USB 2.0 outputs but I only have Firewire on my laptop. When I connect the drive to the laptop using Firewire, Nero recognizes the burner and I can burn cd's. However InCD does not recognize the burner. I switched to USB 1.1 to test if it is my burner or the enclosure that is the problem. Using USB 1.1, InCD does recognize the burner. I am using a 52x24x52 Lite-on burner.
I have no idea how to fix this because of all the places it could go wrong:
Burner - unlikely
Enclosure - unlikely
Firewire card/drivers - likely
InCD program - likely
Where do I start?
MadDog5145
Postby MadDog5145 on Sat Mar 01, 2003 3:55 pm
Nevermind. Solved my own problem within in 15 minute of posting, LOL.
If you are curious, I had my burner as slave in the enlosure so switched it to master to see if it did anything. Well, that fixed the problem.
MadDog5145
Postby cfitz on Sat Mar 01, 2003 7:58 pm
Thanks for the followup. It might help someone in the future.
