InCD 4291 Problem
InCD 4291 Problem
Postby jimb11 on Mon Jul 12, 2004 8:46 pm
I just updated to InCD 4291 from InCD 4054 and now I can't eject my
cd-rw disk when I press the eject button on the burner. I used to be
able to eject my disk using the burner button when I was using InCD
4054 but it doesn't work with InCD 4291. Anyone else having this problem?
Thank you,
Jim
jimb11
Postby dburg on Tue Jul 13, 2004 6:09 am
Btw, I am currently collecting information from Jim's case. If other people have same problem, please report device model, fw revision, operating system and InCD revision. Thanks!
David Burg
Nero AG - Im Stoeckmaedle 18
76307 Karlsbad - Germany
dburg
Postby pranav81 on Tue Jul 13, 2004 6:24 am
Jim,does the disc come out when you right click the drive and select Eject in My Computer or Windows Explorer?
::Pranav::
pranav81
Postby jimb11 on Tue Jul 13, 2004 11:42 am
Pranav81:
Yes it does. The thing is when I had InCD v4054 I could eject the disc by pressing the eject button on the burner but I can't do that with InCD v4291.
jimb11
Postby pranav81 on Wed Jul 14, 2004 5:56 am
Did you try removing and reinstalling InCD?Also while installing new InCD,did you remove the older one or simply upgarded it?
::Pranav::
pranav81
