Ian wrote:I've found that most addon IDE cards don't work well with ATAPI devices. You'd be better off putting it on the same IDE chain as the CD-RW.
You probably won't see any decrease in performance as long as you're not trying to write to both at the same time or copying between the two.
| All Content is Copyright (c) 2001-2025 CDRLabs Inc. |
