How do I upgrade my old USB port to USB2.0/Firewire?
Postby bsulliva on Tue May 13, 2003 12:48 am
Hello all.
I'm a novice in the land of CD burning so be gentle.
I have an IBM Thinkpad T22 running Windows ME which is a couple of years old now so I'm assuming my only USB port is 1.1 at best. I need a CD burner for creating CD photo albums and backing up my hard drive files. I like the idea I've seen in a couple of postings where you hook up an external enclosure to a laptop that houses an internal burner.
Question is, how do I get from USB 1.1 to a position where I can use a SUB2.0/Firewire device? Assuming you're USB2.0 compliant, do these enclosures then connect to a laptop via the USB2.0 port?
I've seen a couple of PCMCIA adapter cards that might do the trick - can anyone recommend some good ones, particulary those that support USB2.0 and Firewire? Are there any other options or is PCMCIA the only way ahead?
Many thanks for your patience,
Ben
bsulliva
Postby Boone on Tue May 13, 2003 1:16 am
I've responded to your post in General Hardware Questions. Please only make 1 post from now on. Thanks!
http://www.cdrlabs.com/phpBB/viewtopic.php?t=10818
Boone
